[mpich-discuss] MPICH2
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Jun  9 14:32:38 CDT 2011
 If you have installed MPICH2 on versions of Windows post-Vista (Vista, Windows 7, long horn etc), try running the cygwin bash shell from an administrative command prompt (Right-click on command prompt icon and select "Run as administrator" . From within this command prompt type "bash" to run the cygwin bash shell.) and let us know if it works.
Jayesh
----- Original Message -----
Sent: Saturday, June 4, 2011 5:35:10 PM
Subject: [mpich-discuss] MPICH2
Hello
I just installed cygwin mpich2 . when I tried a simple example cpi.c I had the following error :
mpiexec -n 2 ./cpi.exe
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(388).....:
MPID_Init(139)............: channel initialization failed
MPIDI_CH3_Init(38)........:
MPID_nem_init(196)........:
MPIDI_CH3I_Seg_commit(388):
MPIU_SHMW_Seg_detach(707).: unable to remove shared memory - unlink Permission d
enied
[mpiexec at port-mn] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
you find attached
mpich2-1.3.2p1/c.txt (generated in step 1(d) above)
mpich2-1.3.2p1/m.txt (generated in step 1(e) above)
mpich2-1.3.2p1/mi.txt (generated in step 1(f) above)
mpich2-1.3.2p1/config.log (generated in step 1(d) above)
mpich2-1.3.2p1/src/openpa/config.log (generated in step 1(d)
cordially
Mourad
mpich-discuss mailing list
