[mpich-discuss] SMPD passphrase?
    Jose Pascual-Gutierrez
    Jose.Pascual-Gutierr at 1-act.com
    Tue Jun  7 11:15:47 CDT 2011
Before launching a smpd job, one needs to get smpd running on a node with the command "smpd -s". This propmts the user to create a ~/.smpd configuration file and passphrase if it did not exist already.
I then tried to run the cpi example with the following result:
$ mpiexec -n 1 ./cpi.exe
Process 0 of 1 is on IT-00089
pi is approximately 3.1415926544231341, Error is 0.0000000008333410
wall clock time = 0.000000
os_error = 104 (Connection reset by peer)
SMPDU_Sock_wait failed,
sock error: Error = -1
state machine failed.
The same error would happen when launching two processes:
$ mpiexec -n 2 ./cpi.exe
Thank you very much for your help,
José
Jose.Pascual-Gutierr at IT-00089 ~/MPICH2/mpich2-1.3.2p1/examples
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
Sent: Tuesday, June 07, 2011 9:33 AM
Subject: Re: [mpich-discuss] SMPD passphrase?
I think you need to configure a passphrase somehow.  I don't use windows so I have no specific idea how to do it.  I suspect, however, that the installer's guide on the mpich2 website contains this information somewhere.
-Dave
On Jun 7, 2011, at 8:25 AM CDT, Jose Pascual-Gutierrez wrote:
> Hello Dave:
> Operating System: Windows 7
> Terminal emulator: Red Hat Cygwin
> Processor: Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93 GHz
> MPICH2 Version: mpich2-1.3.2p1
> Shell: bash
> As recommended in the previous e-mails, I built the mpich2 library using the following commands:
> $ ./configure --prefix=/home/<USERNAME>/mpich2-install-smpd
> --with-pm=smpd  --with-pmi=smpd  2>&1 | tee c.txt $ make 2>&1 | tee
> m.txt $ make install 2>&1 | tee mi.txt
> The installation seemed successful. I tried running the example file cpi and I was prompted for an authentication passphrase:
> Please specify an authentication passphrase for smpd:
> Is there such a passphrase that I need to know?
> José
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jose
> Pascual-Gutierrez
> Sent: Friday, June 03, 2011 4:12 PM
> Subject: Re: [mpich-discuss] mpiexec does not run
> Thank you, Dave, I will give it a try.
> J
> Sent: Friday, June 03, 2011 4:11 PM
> Add "--with-pm=smpd" to your configure command.  You might also need to add "--with-pmi=smpd" to get everything working in the end; I can't remember if that's necessary or if it's handled automatically for you.
> -Dave
> On Jun 3, 2011, at 2:53 PM CDT, Jose Pascual-Gutierrez wrote:
>> Thank you very much Dave for your message.
>> How do I "use SMPD instead". Does it imply a new installation with other configuration, or would it be as simple as adding an argument to the mpiexec command?
>> Thank you,
>> José
>> Sent: Friday, June 03, 2011 3:51 PM
>> AFAIK hydra does not work on Windows yet, even under cygwin.  Use SMPD instead.  If you really need hydra, you'll need to use a non-Windows OS.
>> http://trac.mcs.anl.gov/projects/mpich2/ticket/1050
>> -Dave
>> On Jun 3, 2011, at 2:44 PM CDT, Jose Pascual-Gutierrez wrote:
>>> Thank you very much for your message.
>>> I am running Windows 7 running an Intel(R) Core(TM)2 Duo CPU E7500 @
>>> 2.93 GHz processor. I installed Red Hat Cygwin to emulate a Linux
>>> terminal. All the mpich2-1.3.2p1 installation has been done within
>>> Red Hat Cygwin.
>>> The error I get running cpi.exe is the same as previously. Here is a
>>> copy of the output:
>>> $ mpiexec -n 1 .cpi.exe
>>> Process 0 of 1 is on IT-0089
>>> Pi is approximately 3.1415926544231341, Error is 0.0000000008333410
>>> Wall clock time = 0.000000 [mpiexec at IT-0089] control_cb
>>> (./pm/pmiserv/pmiserv_cb.c:150): assert
>>> (!closed) failed
>>> [mpiexec at IT-0089] HYDT_dmxu_poll_wait_for_event
>>> (./tools/demux_poll.c:77): callback returned error status
>>> [mpiexec at IT-0089] HYD_pmci_wait_for_completion
>>> (./pm/pmiserv/pmiserv_pmci.c:206): error waiting for event
>>> [mpiexec at IT-0089] main (./ui/mpich/mpiexec.c:404): process manager
>>> error waiting for completion
>>> $ mpiexec -n 2 .cpi.exe
>>> Pi is approximately 3.141592654431318, Error is 0.0000000008333387
>>> Wall clock time = 0.000000 Process 1 of 2 is on IT-00089
>>> Thank you so much once again for all your help.
>>> J
>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius
>>> Buntinas
>>> Sent: Friday, June 03, 2011 3:11 PM
>>> What OS are you using?  Try running cpi in the examples directory.
>>> -d
>>> On Jun 3, 2011, at 1:11 PM, Jose Pascual-Gutierrez wrote:
>>>> To whom it may concern:
>>>> The MPICH2 version 1.3.2p1 installation seemed successful. I can
>>>> compile codes using the
>>>> mpif90 compiler. I can run the executable, let's say a.exe, by
>>>> typing in  the command line ./a.exe. In the execution, the MPI
>>>> functions seem
>>>> to work  well. However, when I try to execute mpiexec, I get the
>>>> following error
>>>> message:
>>>> $mpiexec -n 1 ./a.exe
>>>> [mpiexec at IT-0089] control_cb (./pm/pmiserv/pmiserv_cb.c:150):
>>>> assert
>>>> (!closed) failed
>>>> Exactly the same error message is obtained trying with two
>>>> processors
>>> "mpiexec -n 2 ./a.exe"
>>>> Any help would very much appreciated. Thank you very much
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
