[mpich-discuss] mpiexec does not run
Dave Goodell goodell at mcs.anl.gov
Fri Jun 3 15:11:17 CDT 2011
Add "--with-pm=smpd" to your configure command.  You might also need to add "--with-pmi=smpd" to get everything working in the end; I can't remember if that's necessary or if it's handled automatically for you.
-Dave
On Jun 3, 2011, at 2:53 PM CDT, Jose Pascual-Gutierrez wrote:
> Thank you very much Dave for your message.
> How do I "use SMPD instead". Does it imply a new installation with other configuration, or would it be as simple as adding an argument to the mpiexec command?
> Thank you,
> José
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
> Sent: Friday, June 03, 2011 3:51 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpiexec does not run
> AFAIK hydra does not work on Windows yet, even under cygwin.  Use SMPD instead.  If you really need hydra, you'll need to use a non-Windows OS.
> http://trac.mcs.anl.gov/projects/mpich2/ticket/1050
> -Dave
> On Jun 3, 2011, at 2:44 PM CDT, Jose Pascual-Gutierrez wrote:
>> Thank you very much for your message.
>> I am running Windows 7 running an Intel(R) Core(TM)2 Duo CPU E7500 @
>> 2.93 GHz processor. I installed Red Hat Cygwin to emulate a Linux
>> terminal. All the mpich2-1.3.2p1 installation has been done within Red
>> Hat Cygwin.
>> The error I get running cpi.exe is the same as previously. Here is a
>> copy of the output:
>> $ mpiexec -n 1 .cpi.exe
>> Process 0 of 1 is on IT-0089
>> Pi is approximately 3.1415926544231341, Error is 0.0000000008333410
>> Wall clock time = 0.000000 [mpiexec at IT-0089] control_cb
>> (./pm/pmiserv/pmiserv_cb.c:150): assert
>> (!closed) failed
>> [mpiexec at IT-0089] HYDT_dmxu_poll_wait_for_event
>> (./tools/demux_poll.c:77): callback returned error status
>> [mpiexec at IT-0089] HYD_pmci_wait_for_completion
>> (./pm/pmiserv/pmiserv_pmci.c:206): error waiting for event
>> [mpiexec at IT-0089] main (./ui/mpich/mpiexec.c:404): process manager
>> error waiting for completion
>> $ mpiexec -n 2 .cpi.exe
>> Pi is approximately 3.141592654431318, Error is 0.0000000008333387
>> Wall clock time = 0.000000 Process 1 of 2 is on IT-00089
>> Thank you so much once again for all your help.
>> J
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius
>> Buntinas
>> Sent: Friday, June 03, 2011 3:11 PM
>> What OS are you using?  Try running cpi in the examples directory.
>> -d
>> On Jun 3, 2011, at 1:11 PM, Jose Pascual-Gutierrez wrote:
>>> To whom it may concern:
>>> The MPICH2 version 1.3.2p1 installation seemed successful. I can
>>> compile codes using the
>>> mpif90 compiler. I can run the executable, let's say a.exe, by typing
>>> in  the command line ./a.exe. In the execution, the MPI functions
>>> seem
>>> to work  well. However, when I try to execute mpiexec, I get the
>>> following error
>>> message:
>>> $mpiexec -n 1 ./a.exe
>>> [mpiexec at IT-0089] control_cb (./pm/pmiserv/pmiserv_cb.c:150): assert
>>> (!closed) failed
>>> Exactly the same error message is obtained trying with two processors
>> "mpiexec -n 2 ./a.exe"
>>> Any help would very much appreciated. Thank you very much
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
