[mpich-discuss] mpiexec does not run
    Jose Pascual-Gutierrez
    Jose.Pascual-Gutierr at 1-act.com
    Fri Jun  3 14:44:05 CDT 2011
Thank you very much for your message.
I am running Windows 7 running an Intel(R) Core(TM)2 Duo CPU E7500 @
2.93 GHz processor. I installed Red Hat Cygwin to emulate a Linux
terminal. All the mpich2-1.3.2p1 installation has been done within Red
Hat Cygwin.
The error I get running cpi.exe is the same as previously. Here is a
copy of the output:
$ mpiexec -n 1 .cpi.exe
Process 0 of 1 is on IT-0089
Pi is approximately 3.1415926544231341, Error is 0.0000000008333410
Wall clock time = 0.000000
[mpiexec at IT-0089] control_cb (./pm/pmiserv/pmiserv_cb.c:150): assert
(!closed) failed
[mpiexec at IT-0089] HYDT_dmxu_poll_wait_for_event
(./tools/demux_poll.c:77): callback returned error status
[mpiexec at IT-0089] HYD_pmci_wait_for_completion
(./pm/pmiserv/pmiserv_pmci.c:206): error waiting for event
[mpiexec at IT-0089] main (./ui/mpich/mpiexec.c:404): process manager error
waiting for completion
$ mpiexec -n 2 .cpi.exe
Pi is approximately 3.141592654431318, Error is 0.0000000008333387
Process 1 of 2 is on IT-00089
Thank you so much once again for all your help.
J
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius Buntinas
Sent: Friday, June 03, 2011 3:11 PM
Subject: Re: [mpich-discuss] mpiexec does not run
What OS are you using?  Try running cpi in the examples directory.
-d
On Jun 3, 2011, at 1:11 PM, Jose Pascual-Gutierrez wrote:
> To whom it may concern:
> The MPICH2 version 1.3.2p1 installation seemed successful. I can
> compile codes using the
> mpif90 compiler. I can run the executable, let's say a.exe, by typing
> in  the command line ./a.exe. In the execution, the MPI functions seem
> to work  well. However, when I try to execute mpiexec, I get the
> following error
> message:
> $mpiexec -n 1 ./a.exe
> (!closed) failed
> error  waiting for completion
> Exactly the same error message is obtained trying with two processors
"mpiexec -n 2 ./a.exe"
> Any help would very much appreciated. Thank you very much
> mpich-discuss mailing list
