[mpich-discuss] NO_Port Error
Cristina Montañola cristina.montanola at bsc.es
Thu Jun 2 05:26:20 CDT 2011
Hi Dave,
> If upgrading the OS is too difficult, you could install a newer version of MPICH2 from source instead.  It's not too difficult, although you probably won't be able to use any of the other packages in the OS distribution that depend on MPICH2, if that matters to you.
> -Dave
Thanks for your suggestion! I Installed the latest version of mpich2 for
natty and it worked!!
Cristina
WARNING / LEGAL TEXT: This message is intended only for the use of the
individual or entity to which it is addressed and may contain
information which is privileged, confidential, proprietary, or exempt
from disclosure under applicable law. If you are not the intended
recipient or the person responsible for delivering the message to the
intended recipient, you are strictly prohibited from disclosing,
distributing, copying, or in any way using this message. If you have
received this communication in error, please notify the sender and
destroy and delete any copies you may have received.
http://www.bsc.es/disclaimer.htm
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110602/1e35d602/attachment.htm>
