[mpich-discuss] MPICH2 installation
YAKUN ZHU yakun.zhu at utah.edu
Wed Jun 1 20:19:11 CDT 2011
To Whom It May Concern,
I am a student a the Metallurgical Engineering Department, University of Utah. My name is Yakun. I am trying to install MPICH2 to my Opensuse Linux system. There is a problem when the installation proceeded to Step 5. The following is script:
yakun at free-lab-06:~> mkdir /tmp/yakun/mpich2-1.3.2p1
mkdir: cannot create directory `/tmp/yakun/mpich2-1.3.2p1': No such file or directory
yakun at free-lab-06:~> mkdir /home/yakun/mpich2-install
mkdir: cannot create directory `/home/yakun/mpich2-install': File exists
yakun at free-lab-06:~> mkdir /home/yakun/mpich2-1.3.2p1
mkdir: cannot create directory `/home/yakun/mpich2-1.3.2p1': File exists
yakun at free-lab-06:~> cd /home/yakun/mpich2-install
yakun at free-lab-06:~/mpich2-install> mkdir /home/yakun/mpich2-1.3.2p1
yakun at free-lab-06:~/mpich2-install> cd /home/yakun
yakun at free-lab-06:~> mkdir /temporary/yakun/mpich2-1.3.2p1
mkdir: cannot create directory `/temporary/yakun/mpich2-1.3.2p1': No such file or directory
yakun at free-lab-06:~> mkdir /home/yakun/mpich2-1.3.2p1-tmp
yakun at free-lab-06:~> prefix
If 'prefix' is not a typo you can use command-not-found to lookup the package that contains it, like this:
    cnf prefix
yakun at free-lab-06:~> -prefix
If '-prefix' is not a typo you can use command-not-found to lookup the package that contains it, like this:
    cnf -prefix
yakun at free-lab-06:~> cnf prefix
prefix: command not found
yakun at free-lab-06:~> cnf -prefix
-prefix: command not found
yakun at free-lab-06:~> --enable-g=dbg,mem,log
If '--enable-g=dbg,mem,log' is not a typo you can use command-not-found to lookup the package that contains it, like this:
    cnf --enable-g=dbg,mem,log
yakun at free-lab-06:~> cnf --enable-g=dbg,mem,log
--enable-g=dbg,mem,log: command not found
yakun at free-lab-06:~> cd /home/yakun/mpich2-1.3.2p1-tmp
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> /home/yakun/libraries/mpich2-1.3.2p1/configure \
> -prefix=/home/yakun/mpich2-install |& tee c.txt
bash: /home/yakun/libraries/mpich2-1.3.2p1/configure: No such file or directory
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> /home/yakun/libraries/mpich2-1.3.2p1/configure -prefix=/home/yakun/mpich2-install |& tee c.txt
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> /home/yakun/libraries/mpich2-1.3.2p1/configure/-prefix=/home/yakun/mpich2-install |& tee c.txt
bash: /home/yakun/libraries/mpich2-1.3.2p1/configure/-prefix=/home/yakun/mpich2-install: No such file or directory
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> /home/yakun/libraries/mpich2-1.3.2p1/configure/prefix=/home/yakun/mpich2-install |& tee c.txt
bash: /home/yakun/libraries/mpich2-1.3.2p1/configure/prefix=/home/yakun/mpich2-install: No such file or directory
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> /home/yakun/libraries/mpich2-1.3.2p1/configure \-prefix=/home/yakun/mpich2-install |& tee c.txt
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> /home/yakun/libraries/mpich2-1.3.2p1/configure/tmp \-prefix=/home/yakun/mpich2-install |& tee c.txt
bash: /home/yakun/libraries/mpich2-1.3.2p1/configure/tmp: No such file or directory
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> /home/yakun/libraries/mpich2-1.3.2p1-tmp/configure \-prefix=/home/yakun/mpich2-install |& tee c.txt
bash: /home/yakun/libraries/mpich2-1.3.2p1-tmp/configure: No such file or directory
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> /home/yakun/libraries/mpich2-1.3.2p1-tmp/configure/-prefix=/home/yakun/mpich2-install |& tee c.txt
bash: /home/yakun/libraries/mpich2-1.3.2p1-tmp/configure/-prefix=/home/yakun/mpich2-install: No such file or directory
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> /home/yakun/mpich2-1.3.2p1-tmp/configure/-prefix=/home/yakun/mpich2-install |& tee c.txt
bash: /home/yakun/mpich2-1.3.2p1-tmp/configure/-prefix=/home/yakun/mpich2-install: No such file or directory
bash: /home/yakun/mpich2-1.3.2p1-tmp/configure: No such file or directory
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> configure
If 'configure' is not a typo you can use command-not-found to lookup the package that contains it, like this:
    cnf configure
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> ./configure
bash: ./configure: No such file or directory
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> make |& tee m.txt
make: *** No targets specified and no makefile found.  Stop.
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> make clean
make: *** No rule to make target `clean'.  Stop.
yakun at free-lab-06:~/mpich2-1.3.2p1-tmp> make VERBOSE=1 |& tee m.txt
The reason why I am trying to install MPICH2 is before installing Lammps MPICH2 may need to be installed. I spent lots of time on the installation of Lammps but still failed. Can you please give me some hints on how to install Lammps eaisily?
Sincerely,
Yakun Zhu
