[mpich-discuss] Announcing the availability of mpich2-1.3.2
Pavan Balaji
balaji at mcs.anl.gov
Mon Jan 31 20:00:40 CST 2011
A new version of MPICH2 (1.3.2) is available for download from
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
MPICH2-1.3.2 is primarily a bug-fix release. A few small features have
also been added as listed below. All users using older releases of
MPICH2 are encouraged to upgrade to this version. Please try it out and
let us know if you encounter any problems at mpich-discuss at mcs.anl.gov.
Windows binaries are also available from the downloads page.
The MPICH2 Team
Changes in 1.3.2
# OVERALL: MPICH2 now recognizes the OSX mach_absolute_time as a
native timer type.
# OVERALL: Performance improvements to MPI_Comm_split on large
systems.
# OVERALL: Several improvements to error returns capabilities in the
presence of faults.
# PM/PMI: Several fixes and improvements to Hydra's process binding
capability.
# PM/PMI: Upgrade the hwloc version to 1.1.1.
# PM/PMI: Allow users to sort node lists allocated by resource
managers in Hydra.
# PM/PMI: Improvements to signal handling. Now Hydra respects Ctrl-Z
signals and passes on the signal to the application.
# PM/PMI: Improvements to STDOUT/STDERR handling including improved
support for rank prepending on output. Improvements to STDIN
handling for applications being run in the background.
# PM/PMI: Split the bootstrap servers into "launchers" and "resource
managers", allowing the user to pick a different resource manager
from the launcher. For example, the user can now pick the "SLURM"
resource manager and "SSH" as the launcher.
# PM/PMI: The MPD process manager is deprecated.
# WINDOWS: Adding support for gfortran and 64-bit gcc libs.
# Several other minor bug fixes, memory leak fixes, and code cleanup.
A full list of changes is available using:
svn log -r7457:HEAD
https://svn.mcs.anl.gov/repos/mpi/mpich2/tags/release/mpich2-1.3.2
... or at the following link:
https://trac.mcs.anl.gov/projects/mpich2/log/mpich2/tags/release/mpich2-1.3.2?action=follow_copy&rev=HEAD&stop_rev=7457&mode=follow_copy
Pavan Balaji
http://www.mcs.anl.gov/~balaji
