[mpich-discuss] DataType Problem
Anthony Chan
chan at mcs.anl.gov
Mon Jan 31 17:00:59 CST 2011
P3DFFT is available with source code, so you can compile it yourself
on any platforms. You may want to a look into how it uses all2all to do
transposition for 3D FFT so you can code a version that suits your need.
A.Chan
----- Original Message -----
> Yes, I did but I prefer the handle it personally to have more control
> on
> what I am doing. Besides, I cannot be sure such a library is available
> on every supercomputer I will use during my PhD.
> Finally, I have some intermediate steps to do in between a 1D
> transposition and the following one.
> Michele
> On Mon, 2011-01-31 at 16:22 -0600, Anthony Chan wrote:
> > Given you are using all2all to do transposition, did you look into
> > using existing library, e.g. P3DFFT (it is a fortran library) ?
> > A.Chan
> > > Hi Jim,
> > > first of all thanks a lot for your help.
> > > During the week end I completely rewrite the subroutine. Now it
> > > works
> > > but still I have small problems.
> > > What I am trying to accomplish is a matrix transposition.
> > > I need to perform a 3D FFT on a N^3 matrix, where N is always a
> > > power
> > > of
> > > 2.
> > > I am using a 2D domain decomposition. The problem is that the
> > > first
> > > fft
> > > (from real to complex) results in N/2+1 points along the
> > > coordinate 1.
> > > When I transpose from direction 1 to direction 2 (along columns in
> > > my
> > > setup) not all the processors have the same amount of data.
> > > I attached the current subroutine I am using (do not consider
> > > sgt23_pmu
> > > since it will serve for the transposition 2->3 and it is not
> > > complete
> > > yet).
> > > If I perform the direct transposition (1-->2) with the new
> > > subroutine,
> > > it works perfectly. The only problem is that it crashes if I try
> > > to
> > > free
> > > the datatype at the end.
> > > If I perform the inverse transposition (2-->1), it works as
> > > expected
> > > only if I use a number of processors which is a perfect square
> > > (say
> > > 16 ).
> > > If I try with 8 processors for example ( so the domain is
> > > decomposed
> > > into beams with a rectangular base ) the inverse transposition
> > > does
> > > not
> > > work anymore and i receive the following message:
> > > Fatal error in MPI_Alltoallw: Pending request (no error), error
> > > stack:
> > > MPI_Alltoallw(485): MPI_Alltoallw(sbuf=0x1eb9390, scnts=0x1e9c780,
> > > sdispls=0x1e9ee80, stypes=0x1e9eea0, rbuf=0x1e9dc70,
> > > rcnts=0x1e9eec0,
> > > rdispls=0x1e9f100, rtypes=0x1e9ca90, comm=0x84000004) failed
> > > (unknown)(): Pending request (no error)
> > > stack:
> > > MPI_Alltoallw(485): MPI_Alltoallw(sbuf=0x1cf5370, scnts=0x1cf1780,
> > > sdispls=0x1cf3e80, stypes=0x1cf3ea0, rbuf=0x1cf2c70,
> > > rcnts=0x1cf3ec0,
> > > rdispls=0x1cf4100, rtypes=0x1cf1a70, comm=0x84000004) failed
> > > rank 5 in job 26 enterprise_57863 caused collective abort of all
> > > ranks
> > > exit status of rank 5: killed by signal 9
> > > stack:
> > > MPI_Alltoallw(485): MPI_Alltoallw(sbuf=0x218e5a0, scnts=0x2170780,
> > > sdispls=0x2170a40, stypes=0x2170a60, rbuf=0x218c180,
> > > rcnts=0x2170a80,
> > > rdispls=0x2170d10, rtypes=0x2170d30, comm=0x84000004) failed
> > > So my problems are essentially two:
> > > 1) Unable to free the datatypes
> > > 2) Unable to perform the backward transposition when N_proc is not
> > > perfect square.
> > > Again, thanks a lot for your help,
> > > Michele
> > > On Mon, 2011-01-31 at 13:44 -0600, James Dinan wrote:
> > > > Hi Michele,
> > > > I've attached a small test case derived from what you sent. This
> > > > runs
> > > > fine for me with the integer change suggested below.
> > > > I'm still a little confused about the need for
> > > > mpi_type_create_resized(). You're setting the lower bound to 1
> > > > and
> > > > the
> > > > extent to the size of a double complex. These adjustments are in
> > > > bytes,
> > > > so if I'm interpreting this correctly you are effectively
> > > > shifting
> > > > the
> > > > beginning of the data type 1 byte into the first value in the
> > > > array
> > > > and
> > > > then accessing a full double complex from that location. This
> > > > seems
> > > > like it's probably not what you would want to do.
> > > > Could you explain the subset of the data you're trying to cover
> > > > with
> > > > the
> > > > datatype?
> > > > Thanks,
> > > > ~Jim.
> > > > On 01/31/2011 11:13 AM, James Dinan wrote:
> > > > > Hi Michele,
> > > > > Another quick comment:
> > > > > Don't forget to free your MPI datatypes when you're finished
> > > > > with
> > > > > them.
> > > > > This shouldn't cause the error you're seeing, but it can be a
> > > > > resource
> > > > > leak that builds up over time if you call this routine
> > > > > frequently.
> > > > > call mpi_type_free(temp, errorMPI)
> > > > > call mpi_type_free(temp2, errorMPI)
> > > > > call mpi_type_free(temp3, errorMPI)
> > > > > Best,
> > > > > ~Jim.
> > > > > On 01/31/2011 11:07 AM, James Dinan wrote:
> > > > >> Hi Michele,
> > > > >> I'm looking this over and trying to put together a test case
> > > > >> from
> > > > >> the
> > > > >> code you sent. One thing that looks questionable is the type
> > > > >> for
> > > > >> 'ext'.
> > > > >> The call to mpi_type_size wants an integer, however the
> > > > >> mpi_type_create_resized calls want an integer of
> > > > >> kind=MPI_ADDRESS_KIND.
> > > > >> Could you try adding something like this:
> > > > >> integer :: dcsize
> > > > >> integer (kind=MPI_ADDRESS_KIND) :: ext
> > > > >> call mpi_type_size( mpi_double_complex , dcsize , errorMPI)
> > > > >> ext = dcsize
> > > > >> Thanks,
> > > > >> ~Jim.
> > > > >> On 01/30/2011 02:15 AM, Michele Rosso wrote:
> > > > >>> Hi,
> > > > >>> I am developing a subroutine to handle the communication
> > > > >>> inside
> > > > >>> a group
> > > > >>> of processors.
> > > > >>> The source code is attached.
> > > > >>> Such subroutine is contained in a module and accesses many
> > > > >>> of
> > > > >>> the data
> > > > >>> it needs and the header "mpi.h" from another module
> > > > >>> (pmu_var).
> > > > >>> As an input I have a 3D array (work1) which is allocated in
> > > > >>> the
> > > > >>> main
> > > > >>> program. As an output I have another 3D matrix (work2) which
> > > > >>> is
> > > > >>> allocated in the main program too. Both of them are of type
> > > > >>> complex and
> > > > >>> have intent INOUT (I wanna use the subroutine in a
> > > > >>> reversible
> > > > >>> way ).
> > > > >>> Since the data I wanna send are not contiguous, I defined
> > > > >>> several data
> > > > >>> types. Then I tested all of them with a simple send-receive
> > > > >>> communication in the group "mpi_comm_world".
> > > > >>> The problem arises when I tested the data type "temp3": the
> > > > >>> esecution of
> > > > >>> the program stops and I receive the error:
> > > > >>> rank 0 in job 8 enterprise_45569 caused collective abort of
> > > > >>> all
> > > > >>> ranks
> > > > >>> exit status of rank 0: killed by signal 9
> > > > >>> Notice that work1 and work2 have different size but the same
> > > > >>> shape and
> > > > >>> the data type should be coherent with them.
> > > > >>> Has anyone and idea of which the problem could be?
> > > > >>> Thanks in advance,
> > > > >>> Michele
> > > > >>> _______________________________________________
> > > > >>> mpich-discuss mailing list
> > > > >>> mpich-discuss at mcs.anl.gov
> > > > >>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
