[mpich-discuss] Fatal error in MPI_Init
Jayesh Krishna jayesh at mcs.anl.gov
Fri Jan 28 15:59:22 CST 2011
 It looks like the adapter (driver) does not allow creating TCP/IP sockets (There is no service provided for TCP/IP).
 The next version of MPICH2 on Windows will have a Network Direct module that should allow you to run your application over Infiniband. I don't know when the next version will be out (~ 1-2 months), if you need it sooner please let me know and I can provide a custom build for you.
(PS: Currently MPICH2 on Windows has support for only plain TCP/IP sockets. It does not support Winsock direct or Network Direct.)
Jayesh
----- Original Message -----
Sent: Friday, January 28, 2011 10:52:41 AM
Subject: [mpich-discuss] Fatal error in MPI_Init
Hello everybody!
I'm newbie with MPI, so I think I need your help!
I want to tell you what is my problem:
I have 2 computers connected with Infiniband adapters. On both PCs I'm running Windows XP, and I have installed the correspondent drivers. Then I configured the subnet, and it's possible for me to ping one PC with the other.
After that, I installed MPICH2 (for Windows).
I want to run a simple "Hello World" program (programmed in C), but in the moment when I want to run the program using MPIEXEC, I obtain the following message:
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread<388>..........:
MPID_Init<315>.................: channel initialization failed
MPDIDI_CH3_Init<38>............:
MPID_nem_init<234>.............:
MPID_nem_newtcp_module_init<90>:
MPID_nem_newtcp_module_init<89>: unable to create a socket. No se puede cargar o inicializar el proveedor de servicios solicitado.
<errno 10106>
Am I doing something wrong?
Please! Help me! I'm newbie with MPI.
Thanks!
Gustavo
>From Bariloche (Argentina)
mpich-discuss mailing list
