[mpich-discuss] error in MPI_INIT on 64 bit machine
Jayesh Krishna jayesh at mcs.anl.gov
Thu Jan 27 10:46:03 CST 2011
 The master fails because it is unable to locate mpiexec.exe (c:\Program Files\MPICH2\bin\mpiexec.exe) in your PATH.
 Just add "c:\Program Files\MPICH2\bin" to your system PATH and re-run your master program.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Thursday, January 27, 2011 10:34:38 AM
Subject: RE: [mpich-discuss]  error in MPI_INIT on 64 bit machine
I've tried running the master program without mpiexec, which doesn't allow
to spawn the slave program (see log file).
I've switched to MPICH2 v 1.3.1 and similar errors still occur.
Do you have any other ideas?
By the way, I've seen similar problems with fds-smv
(http://code.google.com/p/fds-smv/issues/detail?id=973), maybe you know
about this?
Best regards,
Frederic
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Tuesday, January 25, 2011 6:16 PM
To: Cugnon
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] error in MPI_INIT on 64 bit machine
 Did you try running the non-matlab program that spawns child processes
without mpiexec (Launch your code by typing the executable name at the
command prompt) ?
 Meanwhile, the version of MPICH2 that you use is old. I would recommend
upgrading to the latest stable version, 1.3.1, of MPICH2 (available at
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downlo
ads). Please uninstall the existing version of MPICH2 before installing the
new version.
Jayesh
Sent: Tuesday, January 25, 2011 10:45:13 AM
Thanks for this quick answer.
In fact, I can spawn my program from another master program (not matlab), I
can also spawn another slave program from matlab, only matlab spawning my
Samcef program doesn't work. So I'm not able to provide a standalone test
case. However, I've joined my test master (fred1.f) and slave (fred.f)
programs if it could help to find any reason for this error. MPI calls of
fred1.f are identical to MPI calls used in the Matlab S-function, while
fred.f makes same MPI calls than my Samcef program.
For your information I'm using mpich2-1.0.8-win-x86-64
Thanks for your help
Sent: Tuesday, January 25, 2011 5:27 PM
Cc: frederic cugnon
 From the error messages it looks like the spawned process is not able to
connect back to the parent process (the parent process TCP/IP port is
blocked) OR the parent process crashed after spawning the child process.
 Can you spawn your program from another MPI program (non-matlab/simulink
MPI program launched from the command line)?
 Try turning off any firewalls running on your system. I don't have Matlab
here - do you have a test case that reproduces the problem (preferably
without using Matlab)?
Jayesh
Sent: Tuesday, January 25, 2011 9:10:58 AM
Subject: [mpich-discuss]  error in MPI_INIT on 64 bit machine
Hi
I have been using MPICH2 to implement co-simulation between Matlab Simulink
and my code. I have implemented a master-slave procedure, launching my code
from a Matlab S-function using MPI_Comm_spawn. Things are working perfectly
on an old Windows XP computer with 32 bit version of both softwares. When I
move to 64 bit versions on Windows Seven system, I have errors when the
slave process calls the MPI_Init function. Depending on the communication
channel that I use (sock or nemesis), I get slightly different error
messages when MPI_Init is called (see attached log files).
Could anybody help me with this problem?
Thanks
Frédéric CUGNON
Samtech SA
Rue des Chasseurs-Ardennais 8
4031 Angleur
tel int-32-4-361.69.69
fax int-32-4-361.69.80
frederic.cugnon at samtech.com
This message has been scanned for viruses and
dangerous content by MailScanner , and is
believed to be clean.
mpich-discuss mailing list
dangerous content by MailScanner, and is
