[mpich-discuss] hydra_pmi_proxy using 100% CPU
Colin Hercus colin at novocraft.com
Fri Jan 21 00:05:13 CST 2011
Hi Pravind,
Thought I'd try MPI-IO that you mentioned so I went to my favourite MPI site
https://computing.llnl.gov/tutorials/mpi/ and there was no mention of it.
There's also no links or documentation on MPICH2 home page so that might
explain why I missed it :)
I've found some documentation and may give it a quick try but I think I've
also fixed my problem.
I had a bash script to monitor the progress of the MPI job that went like:
mpiexec .... >report.file&
while ..
do
    echo `date` `wc -l report.file`
    sleep 30
done
If I monitor file size rather than number of lines using stat -c%s rather
than wc -l then I don't get the slow downs and everything runs perfectly.
It's interesting because server has a lot of ram and the file is in cache.
When I try wc -l on 2G file (maximum size it gets to) it takes about 1sec
and monitoring loop sleeps for 30 secs between each wc -l but it obviously
interferes with mpiexec and hydra_pmi_proxy.
So I'm happy now and thanks for your help. Just knowing mpiexec &
hydra_pmi_proxy CPU was related to stdout IO was enough of a clue to get me
moving in the right direction
Thanks, Colin
On Fri, Jan 21, 2011 at 8:34 AM, Colin Hercus <colin at novocraft.com> wrote:
> Hi Pravind,
>  That's 1Gb of stdout from master process only in in ~ 1hr is that really a
> lot? Writes are in 16K blocks. I also read about the same using stdio
> routines. I'll take a look at MPI-I/O
> Colin
> On Fri, Jan 21, 2011 at 2:53 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
>> On 01/20/2011 09:51 AM, Colin Hercus wrote:
>>> The 1Gb is MPI messages, about the same is written to stdout.
>> 1GB of stdout might cause the proxy and mpiexec to be busy for a long time
>> moving the data. Shouldn't you be considering MPI-I/O if you are writing
>> such large amounts?
>>  My PC for compile and (static) link was at 1.2.1 and I was running on a
>>> server with 1.3.1 when I first noticed this. I then upgraded to 1.3.1
>>> but it made no difference.
>> Yes, mpiexec is backward compatible to any version of MPICH2 (or any other
>> derivative of MPICH2). But it's best to always upgrade to the latest
>> version.
>>  When would mpiexec and hydra_pmi_proxy use CPU? is it just related to
>>> stdout?
>> Mostly, only for stdout/stderr/stdin + when one MPI process needs to know
>> the address of another remote MPI process (typically when you send the first
>> message).
>>  -- Pavan
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji <http://www.mcs.anl.gov/%7Ebalaji>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110121/0b90a248/attachment.htm>
