[mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
    Arun Murthy
    arun.murthy at fluidyn.com
    Tue Jan 11 02:12:01 CST 2011
Hi Jayesh
I opened CMD with "Run as administrator" and did the following:
C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot
c:\tmp\icpi.exe
Job terminated with following error message:
Error posting writev, A request to send or receive data was disallowed
because the socket had already been shut down in that direction with a
previous shutdown call.(10058)
unable to post a write for the next command,
sock error: Error = 10058
unable to post a write of the closed_request command to the parent context.
unable to close the stdin context.
state machine failed.
-exitcodes c:\tmp\icpi.exe
rank: node: exit code
0: Arun-PC: -1073741819
1: Arun-PC: -1073741819
C:\tmp>"C:\Program Files\MPICH2\bin"\smpd -status
smpd running on Arun-PC
Thanks for your help.
Best Regards
Arun
On 10-01-2011 22:08, Jayesh Krishna wrote:
> Hi,
>   Can you try running the job from an administrator command prompt (Note that opening a command prompt from an administrator account does not give you an admin command prompt. Right-click on the command prompt icon and select "Run as administrator" to get an admin command prompt) and see if it works ?
>   Can you also check the status of the MPICH2 process manager (Type "smpd -status" at the command prompt)?
> Regards,
> Jayesh
> From: Arun Murthy<arun.murthy at fluidyn.com>
> To: Jayesh Krishna<jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Mon, 10 Jan 2011 01:33:41 -0600 (CST)
> Subject: Re: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
> Hi Jayesh
> I tried that. It did not help. Here is the response:
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot icpi.exe
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\6308
> registry key, error 5, Access is denied.
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\808
> registry k ey, error 5, Access is denied.
> When I killed the job by<CTRL>  C, the following messages appeared:
> mpiexec aborting job...
> received suspend command for a pmi context that doesn't exist: unmatched
> id = 1
> job aborted:
> rank: node: exit code[: error message]
> 0: Arun-PC: -1073741819: mpiexec aborting job
> Terminate batch job (Y/N)? y
> When I tried the same thing on the pre-built "cpi.exe", I get the same
> messages that I got with "icpi.exe", but it still works:
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot cpi
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\4544
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7288
> Enter the number of intervals: (0 quits) 9
> pi is approximately 3.1426214565576127, Error is 0.0010288029678196
> wall clock time = 0.000077
> When I killed this job by<CTRL>  C, the following messages appeared:
> SuspendThread failed with error 5 for process
> 0:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
> unable to suspend process.
> unable to read the cmd header on the pmi context, Error = -1.
> Error posting readv, An existing connection was forcibly closed by the
> remote host.(10054)
> 1:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
> remote host.(10054)
> received kill command for a pmi context that doesn't exist: unmatched id = 0
> job aborted:
> 0: Arun-PC: 123: process 0 exited without calling finalize
> 1: Arun-PC: 123: process 1 exited without calling finalize
> Does it have anything to do with an incorrect node (-1073741819) on
> which mpiexec is trying to launch the processes? Thanks for your help.
> Best Regards
> Arun
> On 07-01-2011 22:11, Jayesh Krishna wrote:
>> Hi,
>>    Can you try running your program with the "-localroot" option and let us know if it works for you (mpiexec -n 2 -localroot icpi.exe)?
>> Regards,
>> Jayesh
>> From: "Arun Murthy"<arun.murthy at fluidyn.com>
>> To: mpich-discuss at mcs.anl.gov
>> Sent: Friday, January 7, 2011 12:56:17 AM
>> Subject: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
>> Hi
>> I am trying to use MPICH2 on Windows 7 64bit (installed from
>> mpich2-1.3.1-win-x86-64.msi) along with Mingw-w64 compiler suite
>> (mingw-w64-1.0-bin_i686-mingw_20101129).
>> I tried to compile-link the example "icpi.c" using following command:
>> C:\MinGW\mingw-w64-1.0-bin_i686-mingw_20101129\bin\x86_64-w64-mingw32-gcc.exe
>> -I"C:\Program Files\MPICH2\include" icpi.c -L"C:\Program
>> Files\MPICH2\lib" -lmpi -o icpi.exe
>> I could get the executable, but it doesn't run with any number of
>> processors. When run with mpiexec, it aborts without any message. I
>> could run the pre-built "cpi.exe" with any number of CPU's. I don't have
>> MS Visual Studio on my machine. Can anyone help?
>> By the way, the 32-bit version of MPICH1 (1.2.5 SDK.gcc) works well with
>> Mingw-w32 compiler suite.
>> Thanks
>> Arun
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110111/c3ac0bc6/attachment-0001.htm>
