[mpich-discuss] How to implement this case
Eric A. Borisch
eborisch at ieee.org
Wed Jan 5 08:53:30 CST 2011
If I take this code and place it into a simple program as main, it runs just
fine on my machine.
I would look at what you are doing outside of this code... MPI_Finalize()
should only be called once in the program, and I think (can't recall) the
same is true of MPI_Init().
Good luck!
Eric
On Tue, Jan 4, 2011 at 4:36 PM, Xiao Li <shinelee.thewise at gmail.com> wrote:
> Hi Eric,
> I tried to mix MPI_Waitany, MPI_Isend and MPI_Irecv in my code. But I still
> get error like
> Fatal error in PMPI_Wait: Other MPI error, error stack:
> PMPI_Wait(179).......................: MPI_Wait(request=0012FF24,
> status00000001) failed
> MPIR_Wait_impl(69)...................:
> MPIDI_CH3I_Progress(335).............:
> MPID_nem_mpich2_blocking_recv(906)...:
> MPID_nem_newtcp_module_poll(37)......:
> MPID_nem_newtcp_module_connpoll(2655):
> gen_write_fail_handler(1194).........: write to socket failed - The
> specified network name is no longer available.
> Fatal error in MPI_Finalize: Other MPI error, error stack:
> MPI_Finalize(281)....................: MPI_Finalize failed
> MPI_Finalize(209)....................:
> MPID_Finalize(118)...................:
> MPIDI_CH3U_VC_WaitForClose(358)......: an error occurred while the device
> was waiting for all open connections to close
> gen_read_fail_handler(1145)..........: read from socket failed - The
> Below is the sampling code making these error.
> int test_mpi_wait_2(int argc, char* argv[])
> int rank;
> int numprocs;
> MPI_Init(&argc,&argv);
> MPI_Comm_size(MPI_COMM_WORLD,&numprocs);
> MPI_Comm_rank(MPI_COMM_WORLD,&rank);
> int trunk_size = 7;
> int buf_size = 10000;
> if(rank == 0)
> int** b = new int* [numprocs];
> for(int i=0;i<numprocs;i++)
> b[i] = new int [buf_size];
> MPI_Request* requests = new MPI_Request[numprocs];
> for(int i=1;i<numprocs;i++)
> MPI_Irecv(b[i], buf_size, MPI_INT, i, 0, MPI_COMM_WORLD, &requests[i]);
> vector<int> counter(numprocs);
> MPI_Status status;
> for(int i=0;i<(numprocs-1)*trunk_size;i++)
> int active_index;
> MPI_Waitany(numprocs-1, requests+1, &active_index, &status);
> int request_index = active_index + 1;
> int procs_index = active_index + 1;
> cout<<"get " <<b[procs_index][0]<<b[procs_index][1]<<" from
> "<<procs_index<<endl;
> if(++counter[procs_index] != trunk_size)
> cout<<"begin receive next trunk from "<<procs_index<<" remained as
> "<<trunk_size - counter[procs_index]<<endl;
> MPI_Irecv(b[procs_index], buf_size, MPI_INT, procs_index, 0,
> MPI_COMM_WORLD, &requests[request_index]);
> else
> cout<<"finished at "<<procs_index<<" remained as "<<trunk_size -
> cout<<"receiving count"<<endl;
> cout<<counter[i]<<endl;
> delete [] b[i];
> delete [] b;
> delete [] requests;
> cout<<rank<<" done"<<endl;
> else
> int* a[2];
> a[0] = new int [buf_size];
> a[1] = new int [buf_size];
> MPI_Request requests[2];
> //file A bufer
> for(int i=0;i<buf_size;i++)
> a[0][i] = 0;
> MPI_Isend(a[0], buf_size, MPI_INT, 0, 0, MPI_COMM_WORLD, &requests[0]);
> if(trunk_size > 1)
> //file B bufer
> a[1][i] = i;
> MPI_Isend(a[1], buf_size, MPI_INT, 0, 0, MPI_COMM_WORLD, &requests[1]);
> for(int i=2;i<trunk_size;i+=2)
> cout<<rank<<" wait A for trunk "<<i-2<<endl;
> MPI_Wait(&requests[0], MPI_STATUS_IGNORE);
> for(int j=0;j<buf_size;j++)
> a[0][j] = j * i;
> if(i+ 1 < trunk_size)
> cout<<rank<<" wait B for trunk "<<i-1<<endl;
> MPI_Wait(&requests[1], MPI_STATUS_IGNORE);
> a[1][j] = j * (i + 1);
> if(trunk_size == 1)
> cout<<rank<<" wait A for trunk 0"<<endl;
> else
> if(trunk_size % 2)
> cout<<rank<<" wait A for trunk "<<trunk_size-1<<endl;
> cout<<rank<<" wait B for trunk "<<trunk_size-2<<endl;
> else
> cout<<rank<<" wait A for trunk "<<trunk_size-2<<endl;
> cout<<rank<<" wait B for trunk "<<trunk_size-1<<endl;
> delete [] a[0];
> delete [] a[1];
> MPI_Finalize();
> return 0;
> On Tue, Jan 4, 2011 at 1:18 PM, Eric A. Borisch <eborisch at ieee.org> wrote:
>> That shouldn't be the case; the request at index should get set to
>> MPI_REQUEST_NULL and not hurt anything:
>> **** Test program; Only uses two nodes as written!****
>> #include <iostream>
>> #include <mpi.h>
>> int main(int argc, char * argv[])
>> MPI_Init(&argc, &argv);
>> int rank;
>> MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>> #define BUFSIZE (0x1 << 20) // 1M-element
>> #define COUNT 4
>> if (rank == 1)
>> int * buffer = (int *) malloc(BUFSIZE * sizeof(int));
>> for (int i=0; i < COUNT; i++)
>> MPI_Send(buffer, BUFSIZE, MPI_INT, 0, (i*3)%COUNT, MPI_COMM_WORLD);
>> else if (!rank)
>> int * buffers[COUNT];
>> MPI_Request requests[COUNT];
>> buffers[i] = (int *) malloc(BUFSIZE * sizeof(int));
>> MPI_Irecv(buffers[i], BUFSIZE, MPI_INT, 1, i, MPI_COMM_WORLD,
>> requests + i);
>> int rec = 0;
>> while (rec != MPI_UNDEFINED)
>> std::cout << "Waiting... ";
>> if(MPI_Waitany(COUNT, requests, &rec, MPI_STATUS_IGNORE))
>> std::cout << "Error in wait?" << std::endl;
>> break;
>> else if (rec != MPI_UNDEFINED)
>> std::cout << "Received message " << rec;
>> else
>> std::cout << "None left! ";
>> std::cout << " Requests: ";
>> if (requests[i] == MPI_REQUEST_NULL)
>> std::cout << "N"; // NULL
>> else
>> std::cout << "V"; // VALID
>> std::cout << std::endl;
>> MPI_Finalize();
>> return 0;
>> *** Execution output
>> Waiting... Received message 0 Requests: NVVV
>> Waiting... Received message 3 Requests: NVVN
>> Waiting... Received message 2 Requests: NVNN
>> Waiting... Received message 1 Requests: NNNN
>> Waiting... None left! Requests: NNNN
>> -Eric
>> On Mon, Jan 3, 2011 at 10:19 PM, Xiao Li <shinelee.thewise at gmail.com>wrote:
>>> Hi Eric,
>>> The if statement may make some error, I think it should be altered as .
>>> if ++trunk_sent[index] != M do
>>> MPI_Irecv(buffer[index], index, requests[index])
>>> else
>>> //remove the MPIRequest object of finished process, or else it
>>> might be halt forever
>>> remove requests[index]
>>> end
>>> cheers
>>> Xiao
>>> On Mon, Jan 3, 2011 at 4:24 PM, Xiao Li <shinelee.thewise at gmail.com>wrote:
>>>> Hi Eric,
>>>> You are right. An extra MPI_Irecv will be executed at end. Thanks for
>>>> your comment.
>>>> cheers
>>>> Xiao
>>>> On Mon, Jan 3, 2011 at 4:16 PM, Eric A. Borisch <eborisch at ieee.org>wrote:
>>>>> Looks about right... I'm assuming there is a <do actual work here> to
>>>>> be inserted between the MPI_Waitany and MPI_Irecv within the N*M-sized
>>>>> loop.... and I count from 0 rather than 1 by force of habit... :)
>>>>> I think the logic below will end with one extra attempted MPI_Irecv
>>>>> than desired; perhaps change
>>>>> if trunk_sent[index] != M do
>>>>> trunk_sent[index]++
>>>>> end
>>>>> to
>>>>> end
>>>>> -Eric
>>>>> On Mon, Jan 3, 2011 at 3:00 PM, Xiao Li <shinelee.thewise at gmail.com>wrote:
>>>>>> Hi Eric,
>>>>>> Thanks for your detailed suggestion. After read MPI documents, I
>>>>>> propose the following algorithm,
>>>>>> //begin collecting data for the first trunk
>>>>>> for i=1 to N do
>>>>>> MPI_Irecv(buffer[i], i, requests[i])
>>>>>> end
>>>>>> //set data sending counter
>>>>>> for i=1 to N do
>>>>>> trunk_sent[i] = 0
>>>>>> end
>>>>>> for i=1 to N*M do
>>>>>> MPI_Waitany(N, requests, &index, &status)
>>>>>> trunk_sent[index]++
>>>>>> end
>>>>>> end
>>>>>> May I know what is your opinion of this algorithm?
>>>>>> cheers
>>>>>> Xiao
>>>>>> On Mon, Jan 3, 2011 at 3:31 PM, Eric A. Borisch <eborisch at ieee.org>wrote:
>>>>>>> Xiao,
>>>>>>> You should be able to get by with just N buffers, one for each
>>>>>>> client. After you have processed the i-th iteration for client n, re-issue
>>>>>>> an MPI_Irecv with the same buffer. This will match up with the next MPI_Send
>>>>>>> from client n. You don't have to worry about synchronizing -- the MPI_Irecv
>>>>>>> does not need to be posted before the MPI_Send. (But the MPI_Send won't
>>>>>>> complete until it has been, of course...)
>>>>>>> You could always roll your own sockets, but MPI does a nice job of
>>>>>>> managing connections and messages for you. In addition, MPI can be used
>>>>>>> fairly efficiently on a wide range of interconnects, from shared memory to
>>>>>>> Infiniband with little to no change on the user's part.
>>>>>>> In addition, you could likely improve performance in MPI by having
>>>>>>> two sets (call them A and B) of buffers to send from on each worker; one is
>>>>>>> in the "send" state (let's call this one A, started with an MPI_Isend after
>>>>>>> it was initially filled) while you're filling B. After B is filled, initiate
>>>>>>> a new MPI_Isend (very quick) on B and then wait for A's first send
>>>>>>> (MPI_Wait) to complete. Once the first send on A is completed, you can start
>>>>>>> populating A with the next iteration's output, initiate A's send, wait for
>>>>>>> B's send to complete, and the cycle begins again.
>>>>>>> This approach allows you to overlay communication and computation
>>>>>>> times, and still works with the MPI_Waitany() approach to harvesting
>>>>>>> completed jobs in first-completed order on the master. This is an almost
>>>>>>> trivial thing to implement in MPI, but achieving it with sockets requires
>>>>>>> (IMHO) much more programmer overhead...
>>>>>>> Just my 2c.
>>>>>>> Eric
>>>>>>> On Mon, Jan 3, 2011 at 1:24 PM, Xiao Li <shinelee.thewise at gmail.com>wrote:
>>>>>>>> Hi Eric,
>>>>>>>> Assume I have N workers and M trunks of sending data for each worker
>>>>>>>> respectively, then I have to create N*M data buffer for MPI_Irecv usage. Is
>>>>>>>> this method too costly?
>>>>>>>> Or If I write raw socket programming, is that better? Just like
>>>>>>>> traditional client/server socket programming? Master listens on port
>>>>>>>> and spawn a new thread to accept worker's data storage request?
>>>>>>>> cheers
>>>>>>>> Xiao
>>>>>>>> On Mon, Jan 3, 2011 at 2:13 PM, Eric A. Borisch <eborisch at ieee.org>wrote:
>>>>>>>>> Look at the documentation for MPI_Irecv and MPI_Testany ... these
>>>>>>>>> should help you do what you want.
>>>>>>>>> Eric
>>>>>>>>> On Mon, Jan 3, 2011 at 12:45 PM, Xiao Li <
>>>>>>>>>> Hi MPICH2 people,
>>>>>>>>>> Now, I have a application that composed of single master and many
>>>>>>>>>> workers. The application requirement is very simple: workers finish some
>>>>>>>>>> jobs and send data to master and master store these data into files
>>>>>>>>>> separately. I can simply use MPI_Send on worker side to send data to master.
>>>>>>>>>> But master does not know the data sending sequence. Some worker go fast
>>>>>>>>>> while some are slow. More specifically, suppose there are 5 workers, then
>>>>>>>>>> the data send sequence may be 1,3,4,5,2 or 2,5,4,1,3. If I just write a for
>>>>>>>>>> loop for(i=1 to 5) on master side with MPI_Recv to get data, the master and
>>>>>>>>>> some faster worker have to wait for a long time. I know MPI_Gather can
>>>>>>>>>> implement this. But I am not sure is MPI_Gather works parallelly or just a
>>>>>>>>>> sequential MPI_Recv? Another issue is my data is extremely large, more than
>>>>>>>>>> 1GB data needed to be sent to master. If I divide the data into pieces, I do
>>>>>>>>>> not think MPI_Gather can work. I also tried to think about raw socket
>>>>>>>>>> programming, but I do not think it is a good practice. Would you give me
>>>>>>>>>> some suggestion please?
>>>>>>>>>> cheers
>>>>>>>>>> Xiao
>>>>>>>>>> _______________________________________________
>>>>>>>>>> mpich-discuss mailing list
>>>>>>>>>> mpich-discuss at mcs.anl.gov
>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110105/b26ee3f5/attachment-0001.htm>
