[mpich-discuss] How to implement this case
Eric A. Borisch
eborisch at ieee.org
Mon Jan 3 14:31:34 CST 2011
Xiao,
You should be able to get by with just N buffers, one for each client. After
you have processed the i-th iteration for client n, re-issue an MPI_Irecv
with the same buffer. This will match up with the next MPI_Send from client
n. You don't have to worry about synchronizing -- the MPI_Irecv does not
need to be posted before the MPI_Send. (But the MPI_Send won't complete
until it has been, of course...)
You could always roll your own sockets, but MPI does a nice job of managing
connections and messages for you. In addition, MPI can be used fairly
efficiently on a wide range of interconnects, from shared memory to
Infiniband with little to no change on the user's part.
In addition, you could likely improve performance in MPI by having two sets
(call them A and B) of buffers to send from on each worker; one is in the
"send" state (let's call this one A, started with an MPI_Isend after it was
initially filled) while you're filling B. After B is filled, initiate a new
MPI_Isend (very quick) on B and then wait for A's first send (MPI_Wait) to
complete. Once the first send on A is completed, you can start populating A
with the next iteration's output, initiate A's send, wait for B's send to
complete, and the cycle begins again.
This approach allows you to overlay communication and computation times, and
still works with the MPI_Waitany() approach to harvesting completed jobs in
first-completed order on the master. This is an almost trivial thing to
implement in MPI, but achieving it with sockets requires (IMHO) much more
programmer overhead...
Just my 2c.
Eric
On Mon, Jan 3, 2011 at 1:24 PM, Xiao Li <shinelee.thewise at gmail.com> wrote:
> Hi Eric,
> Assume I have N workers and M trunks of sending data for each worker
> respectively, then I have to create N*M data buffer for MPI_Irecv usage. Is
> this method too costly?
> Or If I write raw socket programming, is that better? Just like traditional
> client/server socket programming? Master listens on port and spawn a new
> thread to accept worker's data storage request?
> cheers
> Xiao
> On Mon, Jan 3, 2011 at 2:13 PM, Eric A. Borisch <eborisch at ieee.org> wrote:
>> Look at the documentation for MPI_Irecv and MPI_Testany ... these should
>> help you do what you want.
>> Eric
>> On Mon, Jan 3, 2011 at 12:45 PM, Xiao Li <shinelee.thewise at gmail.com>wrote:
>>> Hi MPICH2 people,
>>> Now, I have a application that composed of single master and many
>>> workers. The application requirement is very simple: workers finish some
>>> jobs and send data to master and master store these data into files
>>> separately. I can simply use MPI_Send on worker side to send data to master.
>>> But master does not know the data sending sequence. Some worker go fast
>>> while some are slow. More specifically, suppose there are 5 workers, then
>>> the data send sequence may be 1,3,4,5,2 or 2,5,4,1,3. If I just write a for
>>> loop for(i=1 to 5) on master side with MPI_Recv to get data, the master and
>>> some faster worker have to wait for a long time. I know MPI_Gather can
>>> implement this. But I am not sure is MPI_Gather works parallelly or just a
>>> sequential MPI_Recv? Another issue is my data is extremely large, more than
>>> 1GB data needed to be sent to master. If I divide the data into pieces, I do
>>> not think MPI_Gather can work. I also tried to think about raw socket
>>> programming, but I do not think it is a good practice. Would you give me
>>> some suggestion please?
>>> cheers
>>> Xiao
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110103/3258cb7f/attachment.htm>
