[mpich-discuss] MPICH2 config hangs
    Anthony Chan
    chan at mcs.anl.gov
    Thu Feb 17 10:17:19 CST 2011
The ANSI C header test actually returns OK but configure just stops for
no good reason.  The test after the AC_HEADER_STDC looks for stddef.h(the
same test returns OK earlier) but the record is in a different config.log.
Is there any reason that you set CPP/CXXCPP to cpp-4 instead of letting configure
looks for what it wants ?
----- Original Message -----
> During the configure phase of installing MPICH2 in cygwin, the tool
> hangs at
> checking for ANSI C header files...
> The same command is successful two times earlier in the script. c.txt
> is attached.
> Thanks,
> Kerry E. Dungan, Ph.D.
> Senior Staff Scientist
> High-Performance Technologies, Inc.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
