[mpich-discuss] mpi/openmp hybrid seg fault
Jack D. Galloway jackg at lanl.gov
Thu Dec 22 16:01:31 CST 2011
I tried setting both KMP_STACKSIZE and OMP_STACKSIZE to very large values
(4G then 8G) but still got the same seg fault.
I tried to compile with gfortran to verify but there are a lot of "kind"
variables that I believe are pinned to ifort (kmp_size_t_kind for example).
When compiling with "-heap-arrays" I still received the same error.
Just a debugging question, if the stacksize was the problem, would that also
show up when running only on one node (which currently works as long as it's
the same node as where mpiexec is executed from)?  Any other ideas?
Stacksize is already unlimited:
galloway at tebow:~/Flow3D/hybrid-test$ ulimit -a
core file size          (blocks, -c) 0
data seg size           (kbytes, -d) unlimited
scheduling priority             (-e) 0
file size               (blocks, -f) unlimited
pending signals                 (-i) 193087
max locked memory       (kbytes, -l) unlimited
max memory size         (kbytes, -m) unlimited
open files                      (-n) 1024
pipe size            (512 bytes, -p) 8
POSIX message queues     (bytes, -q) 819200
real-time priority              (-r) 0
stack size              (kbytes, -s) unlimited
cpu time               (seconds, -t) unlimited
max user processes              (-u) 193087
virtual memory          (kbytes, -v) unlimited
file locks                      (-x) unlimited
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jeff Hammond
Sent: Thursday, December 22, 2011 6:26 AM
To: Anthony Chan; mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] mpi/openmp hybrid seg fault
The portable equivalent of KMP_STACKSIZE is OMP_STACKSIZE.  We have found on
Blue Gene/P that when values of this parameter are too small, segfaults
occur without an obvious indication that this is the problem.  I assume this
is not a platform-specific problem.
The Intel Fortran compiler puts all static arrays on the stack by default.
You can change this.  See
http://software.intel.com/en-us/articles/intel-fortran-compiler-increased-st
ack-usage-of-80-or-higher-compilers-causes-segmentation-fault/
for details, but I recommend you use "-heap-arrays".  GNU Fortran
(gfortran) does not have this problem, so recompiling with it is a fast way
to determine if stack allocation - independent of OpenMP - is the problem.
Jeff
On Thu, Dec 22, 2011 at 1:22 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
>> The fact that I need this to work for the much larger problem is why
>> simply changing static arrays to dynamic equivalents is not a viable
>> solution unfortunately.
> I didn't check your program, but based on your description of problem,
> you may want to increase the stack size of your threaded program.
> Try setting "ulimit -s" and "KMP_STACKSIZE" to what your program's
> need.  See ifort's manpage on KMP_STACKSIZE's definition.
> A.Chan
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov To manage
> subscription options or unsubscribe:
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute jhammond at alcf.anl.gov / (630)
252-5381 http://www.linkedin.com/in/jeffhammond
https://wiki-old.alcf.anl.gov/index.php/User:Jhammond
To manage subscription options or unsubscribe:
