[mpich-discuss] Cannot compile with debugging symbols
Matthew Russell matthew.g.russell at gmail.com
Tue Aug 30 11:12:05 CDT 2011
Hmm, to be honest, I've never debugged a program using MPI, so I'm not
completely sure what I need.  For a seg. fault. what would you suspect I
need?  The model runs on one processor without problems right now.
For your latter comment, I suspect you're right.  Right now I'm working on
building MPICH and the models I need to run with GNU compilers.
Thanks.
On Tue, Aug 30, 2011 at 12:09 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> Do you just need debugging symbols or do you also need support for locating
> MPI processes and viewing MPI message queues with the Totalview debugger?
>  Your configure options are asking for the additional MPI message queue
> debugging.  If you simply need to be able to see debugging symbols in your
> debugger then you can configure instead with "--enable-g=dbg" or
> "CFLAGS=-g".
> Otherwise if you do need support for the special MPI debugging hooks then
> you'll need to build MPICH2 with gcc or some compiler that is capable of
> building shared libraries.
> -Dave
> On Aug 30, 2011, at 10:27 AM CDT, Matthew Russell wrote:
> > Hi,
> > I'm having problems building MPICH2 with debugging symbols.  I'm using OS
> X Lion on an 86x64 box using PGI 10.9 as my compiler.
> > As far as I can tell, the issue is that the builder wants me to use the
> flag -fpic to produce position independent code, but PGI doesn't support the
> -fpic flag for OS X on a 64 bit machine.
> > My problem is with ./src/mpi/debugger/dll_mpich2.c, specifically, here is
> the line the fails while i'm make'ing it.
> > /opt/pgi/osx86-64/10.9/bin/pgcc -fPIC -DHAVE_CONFIG_H -I. -I.
> -I../../include -I../../../src/include -O2 -Msignextend -V   -g  -DNDEBUG
> -DpgiFortran  -I/Users/matt/software/mpich2/mpich2-1.4/src/mpl/include
> -I/Users/matt/software/mpich2/mpich2-1.4/src/openpa/src
> -I/Users/matt/software/mpich2/mpich2-1.4/src/mpid/ch3/include
> -I/Users/matt/software/mpich2/mpich2-1.4/src/mpid/common/datatype
> -I/Users/matt/software/mpich2/mpich2-1.4/src/mpid/common/locks
> -I/Users/matt/software/mpich2/mpich2-1.4/src/mpid/ch3/channels/nemesis/include
> -I/Users/matt/software/mpich2/mpich2-1.4/src/mpid/ch3/channels/nemesis/n
>  emesis/include
> -I/Users/matt/software/mpich2/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include
> -I/Users/matt/software/mpich2/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor
> -I/Users/matt/software/mpich2/mpich2-1.4/src/util/wrappers
> -I/Users/matt/software/mpich2/mpich2-1.4/src/util/wrappers -g -c
> ./dll_mpich2.c -o _sdll_mpich2.o
> > pgcc-Error-Unknown switch: -fPIC
> > pgcc 10.9-0 64-bit target on Apple OS/X -tp nehalem-64
> > Copyright 1989-2000, The Portland Group, Inc.  All Rights Reserved.
> > Copyright 2000-2010, STMicroelectronics, Inc.  All Rights Reserved.
> > make[2]: *** [dll_mpich2.lo] Error 1
> > make[1]: *** [all-postamble] Error 2
> > make: *** [all-redirect] Error 2
> > My configuration options were:
> > ./configure --prefix=/usr/local/mpich2_pg-dbg --enable-f77
> --enable-debuginfo --enable-error-messages=all --enable-g=all
> --enable-fast=none
> > Does any one know how I can get around this?  I need the debug info,
> since the program I'm trying to run with MPICH (CMAQ) seg. faults. right
> away, and I don't know how else to debug it.
> > Note, with my installation (without debugging symbols), I can run all the
> sample programs on multiple processors, etc.
> > Thanks,
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110830/391a8aad/attachment.htm>
