[mpich-discuss] Fwd: mpich2-1.4.1rc1 and DESTDIR behavior (in MacPorts)
    Pavan Balaji
    balaji at mcs.anl.gov
    Thu Aug 25 16:20:27 CDT 2011
Deji, Eric, and other distro maintainers for MPICH2,
We are working on moving the entire MPICH2 build system to full rely on
autotools which have better support for DESTDIR and other settings
during install time. This will be showing up in the 1.5 release that we
are working on.
Sorry, but for the time being, you might have to go with the workaround
as doing two solutions (one for the current build system and one for the
new build system) would be a waste of time and we are really developer
bandwidth limited with the huge list of features that are being planned
for 1.5.
  -- Pavan
On 08/25/2011 12:58 PM, Deji Akingunola wrote:
> I can see this issue made it to 1.4.1 final release. I'm having the
> same problem Eric encountered while trying to build Fedora and RHEL
> RPMs for mpich2-1.4.1 . I think I (and other distro builders) have to
> apply similar workarounds to build packages for 1.4.1
> - Deji
> On Wed, Aug 24, 2011 at 5:41 PM, Eric A. Borisch<eborisch at ieee.org>  wrote:
>> I'm forwarding this to the -discuss group as I see others may be interested....
>>   - Eric
>> ---------- Forwarded message ----------
>> From: Eric A. Borisch<eborisch at macports.org>
>> Date: Thu, Aug 18, 2011 at 11:18 AM
>> Subject: mpich2-1.4.1rc1 and DESTDIR behavior (in MacPorts)
>> To: Pavan Balaji<balaji at mcs.anl.gov>
>> Pavan,
>> Thanks again for your (and the rest of the team's) work on mpich2! As
>> you may recall I maintain the MacPorts mpich2 portfile.
>> I believe the 1.4.1rc1 implementation of DESTDIR is overzealous -- the
>> intention is not to run *in* DESTDIR, but to install a copy of the
>> files [1] that will eventually be placed into prefix info
>> ${DESTDIR}/${prefix} in exactly the same state as if they were
>> directory (make install-ed) into prefix.
>> Here are the changes I've had to apply with the portfile to make this
>> work correctly:
>> (1) We still need to patch createshlib.in as before [2]
>> (2)  Without this set of changes, a number of the files get placed
>> into ${destroot}${destroot}${prefix} (as opposed to
>> ${destroot}${prefix}) during the 'make install DESTDIR=${destroot}'
>> process
>> post-patch {
>>     reinplace -E "s|fix=\\\$\\\{DESTDIR\\\}|fix=|g" \
>>         ${worksrcpath}/Makefile.in
>>     reinplace -E "s|dir=\\\$\\\{DESTDIR\\\}|dir=|g" \
>> (3) Without these changes the DESTDIR (=$(destroot)) directory ends up
>> stored in these files, as well. I haven't verified that this removal
>> is required, but it seemed poor form to leave references to a
>> soon-to-be-nonexistent directory. This could probably also be fixed by
>> patching a Makefile.in somewhere, but this was quicker for me to
>> implement.
>> post-destroot {
>>     reinplace -E "s|${destroot}||g" ${destroot}/${prefix}/bin/mpicxx
>>     reinplace -E "s|${destroot}||g" ${destroot}/${prefix}/bin/mpicc
>>     reinplace -E "s|${destroot}||g" ${destroot}/${prefix}/etc/mpicxx.conf
>>     reinplace -E "s|${destroot}||g" ${destroot}/${prefix}/etc/mpicc.conf
>> I've attached a patchfile describing the effect of the post-patch step
>> (2) above.
>> I haven't updated the portfile in Macports yet; I'll probably wait for
>> the actual release.
>> Thanks, and let me know your thoughts
>>   Eric
>> Eric A. Borisch
>> [1] http://www.gnu.org/prep/standards/html_node/DESTDIR.html
>> [2] https://trac.macports.org/browser/trunk/dports/science/mpich2/files/patch-src-util-createshlib.in
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
