[mpich-discuss] Building with Clang
Tue Aug 23 17:24:58 CDT 2011
On Mon, Aug 22, 2011 at 14:05, Anthony Chan <chan at mcs.anl.gov> wrote:
> try adding pac_c_check_compiler_option_prototest=no to your configure line
> to see configure goes further.
Thanks Anthony and Dave. Configure succeeds this way and the compile went
through just fine (though not with make -j3 due to a Fortran module
problem). I attached config.log in case this helps fix the problems so this
environment trick isn't needed.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110823/0d385125/attachment-0001.htm>
Type: application/x-xz
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110823/0d385125/attachment-0001.bin>
