[mpich-discuss] mpicc built, mpiexec not
Fabio F.Gervasi
fabio.gervasi70 at gmail.com
Tue Aug 23 10:31:56 CDT 2011
Yes, it works!
Now I'm going to try to run..
Thank you!
2011/8/23 Darius Buntinas <buntinas at mcs.anl.gov>
> It looks like maybe you set the install directory the same as the build
> directory. This is not supported. Try it again with separate build and
> install directories.
> -d
> On Aug 23, 2011, at 3:32 AM, Fabio F.Gervasi wrote:
> > Hi,
> > I usually use mpich2-1.2 succesfully.
> > Now I'm trying to install mpich2-1.4.
> > No errors occur about configure and make, make install seem ok.
> > In /bin folder I get:
> > mpicc, mpicxx, mpif77, mpif90
> > But I have not mpiexec.
> > Where do I wrong?
> > In attachment my configure and make logs.
> > Thank you,
> > Fabio.
> > <m.txt><config.log>_______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110823/f487fde7/attachment.htm>
