[mpich-discuss] Reading files in parallel in winxp with mpich2
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Aug 22 18:42:51 CDT 2011
Please go through MPI-IO (http://www.mcs.anl.gov/research/projects/mpi/mpi-standard/mpi-report-2.0/node172.htm#Node172) for more information.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Monday, August 22, 2011 4:58:36 PM
Subject: Re: [mpich-discuss] Reading files in parallel in winxp with mpich2
Hi Jayesh,
I want all the processors to read a file using:
open (unit = 1 , FILE = "body.txt" , status = "old", iostat = status(1))
read (1,fmt=*) no_body_pts
Is this why it can't work?
I tried using :
call
MPI_File_open(MPI_COMM_WORLD,"body.txt",MPI_MODE_RDONLY,MPI_INFO_NULL,fh,ierr)
But I am not sure how each process can read the contents in the file
after that?
Do I use MPI_File_read? I am not sure of the syntax.
Can you help?
Thanks alot!
Yours sincerely,
TAY wee-beng
On 22/8/2011 6:15 PM, Jayesh Krishna wrote:
> Hi,
> Are you using MPI-IO (MPI_File_open()...)? You should make sure that all MPI processes have access to the file (MPICH2 on Windows does not perform automatic file staging).
> Regards,
> Jayesh
> From: "TAY wee-beng"<zonexo at gmail.com>
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, August 18, 2011 1:57:09 PM
> Subject: [mpich-discuss] Reading files in parallel in winxp with mpich2
> Hi,
> I am running winxp under virtualbox.
> I managed to run my mpi code compiled using compaq visual fortran in winxp.
> I run it with wmpiexec with 1-8 processors and it worked fine.
> However when my mpi code requires reading in of files, it worked only if
> I use 1 processor.
> For more than 1 processor, I got the file not found error.
> How can I solved this error? Btw, when using wmpiconfig, I only get 1 host.
> Thank you very much!
> Yours sincerely,
> TAY wee-beng
> mpich-discuss mailing list
