[mpich-discuss] Reading files in parallel in winxp with mpich2
Jayesh Krishna jayesh at mcs.anl.gov
Mon Aug 22 11:15:10 CDT 2011
 Are you using MPI-IO (MPI_File_open()...)? You should make sure that all MPI processes have access to the file (MPICH2 on Windows does not perform automatic file staging).
Jayesh
----- Original Message -----
Sent: Thursday, August 18, 2011 1:57:09 PM
Subject: [mpich-discuss] Reading files in parallel in winxp with mpich2
I am running winxp under virtualbox.
I managed to run my mpi code compiled using compaq visual fortran in winxp.
I run it with wmpiexec with 1-8 processors and it worked fine.
However when my mpi code requires reading in of files, it worked only if
I use 1 processor.
For more than 1 processor, I got the file not found error.
How can I solved this error? Btw, when using wmpiconfig, I only get 1 host.
Thank you very much!
Yours sincerely,
TAY wee-beng
mpich-discuss mailing list
