[mpich-discuss] MPI_REDUCE and complex numbers
Brian Dushaw
dushaw at apl.washington.edu
Fri Aug 19 15:14:24 CDT 2011
Below is a slightly revised version of Jeff's test case, it more
closely mimics the situation of my code. I find it behaves strangely
on a 2 node, 8 processor system (my cluster is shut down at the moment;
I can't fuss with this any more...)
This throws an error message (why?) and produces some strange results.
28800000/64000 = 450 the number of rows of the arrays.
I am using the sunstudio compiler, btw.
> time mpiexec testreduce
Fatal error in PMPI_Reduce: Message truncated, error stack:
MPIDI_CH3U_Receive_data_found(129): Message from rank 0 and tag 11 truncated; 28800000 bytes received but buffer size is 64000
i, x(i), y(i), z(i)
1 (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0)
1 (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0)
(4.0,4.0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0)
2 (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0)
2 (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0)
3 (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0)
3 (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0)
4 (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0)
4 (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0)
5 (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0) (0.0E+0,0.0E+0)
5 (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0)
6 (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0)
6 (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0)
(8.0,8.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0) (4.0,4.0)
7 (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0)
7 (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0)
8 (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0) (1.0,1.0)
8 (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0) (8.0,8.0)
[and so on, until:]
Fatal error in PMPI_Barrier: Other MPI error
The reduced values should be zeros for the first 5 rows.
program main
use mpi
implicit none
integer,parameter :: wp = kind(1.d0)
integer rc
integer rank, worldsize
integer i,j,n,m,itemp
complex(kind=wp),dimension(:,:),allocatable :: x,y,z
call mpi_init(rc)
call mpi_comm_rank(MPI_COMM_WORLD,rank,rc)
call mpi_comm_size(MPI_COMM_WORLD,worldsize,rc)
m = 450
n = 8000
allocate(x(m,n),y(m,n),z(m,n))
x=0.0_wp*x
y=0.0_wp*y
z=0.0_wp*z
do i = 6, 25
do j = 1, n
x(i,j) = (1.0_wp,1.0_wp)
end do
end do
itemp=n*m
call MPI_REDUCE(x,y,itemp,MPI_DOUBLE_COMPLEX,MPI_SUM,0,MPI_COMM_WORLD,rc)
!call mpi_allreduce(x,z,n,MPI_DOUBLE_COMPLEX,MPI_SUM,MPI_COMM_WORLD,rc)
if (rank .eq. 0) then
print*,'i, x(i), y(i), z(i)'
do i = 1, 30
print *, i, (x(i,j), j=1,15)
print *, i, (y(i,j), j=1,15)
! print *, i, (z(i,j), j=1,15)
end do
print *,'the right answer is ',worldsize*(1.0,1.0)
end if
call MPI_BARRIER(MPI_COMM_WORLD,rc)
call MPI_FINALIZE(rc)
stop
end program main
