[mpich-discuss] MPI_REDUCE and complex numbers
    Brian Dushaw
    dushaw at apl.washington.edu
    Fri Aug 19 12:00:32 CDT 2011
On Fri, 19 Aug 2011, Darius Buntinas wrote:
> There isn't a max buffer size (aside from the running out of memory, but you'd get an error for that).  Can you send us a short sample program that demonstrates this?  How many  processes are you using?
> Thanks,
> -d
Its good to know there is not a maximum to the buffer size.  I was using 32 processors
on 1 Intel i7 and 7 AMD quad-core machines; all running a version of 64-bit Suse linux.
As for a test code...  I might be able to try something, but I am pressed for
time at the moment.  I thought I should at least report what may be a problem.
Thx,
B.D.
