[mpich-discuss] RHEL5 yum build doesn't have mpif90?
    Adams, Jeb
    jeba at amgen.com
    Wed Aug 17 12:10:05 CDT 2011
I installed with sudo, to be sure. I included that tidbit to preclude folks replying with "su into root and do the install," as that is not an option.
Your fix seems to have done the trick though, thanks much!
For webcrawling sake:
RHEL mpich2 yum mpif90 mpicc mpixx mpic++
If installing mpich2 from yum repositories, be sure to install both mpich2 and mpich2-devel if you need the compiler wrapper scripts for mpif90, mpixx, mpicc, mpic++.
Jeb Adams, Research Operations Manager
PKDM IS Liaison
> Date: Wed, 17 Aug 2011 10:50:55 -0500
> From: Darius Buntinas <buntinas at mcs.anl.gov>
> Subject: Re: [mpich-discuss] RHEL5 yum build doesn't have mpif90?
> To: mpich-discuss at mcs.anl.gov
> Message-ID: <9C795455-1439-4929-BCFD-739E02B4BA20 at mcs.anl.gov>
> Content-Type: text/plain; charset=us-ascii
> You'll always need sudo to install any software using yum.  I believe you'll
> also need to install the mpich2-dev package to get the compiler wrapper
> scripts.
> -d
> On Aug 17, 2011, at 10:19 AM, Adams, Jeb wrote:
> > Hello,
> > I am trying to enable MPICH2 on a RHEL5 server farm for NONMEM use. Users
> (self included) will never run as root on this machine. I do have sudo and
> used that to install from yum:
> > sudo yum install mpich2.x86_64
> > yum info has the following:
> > [usto-sapp-nmm02 3] ~ > yum info mpich2
> > Loaded plugins: security
> > Installed Packages
> > Arch       : x86_64
> > Version    : 1.2.1p1
> > Release    : 1.el5
> > Repo       : installed
> > Summary    : A high-performance implementation of MPI
> > URL        : http://www.mcs.anl.gov/research/projects/mpich2
> > License    : MIT
> > Description: MPICH2 is a high-performance and widely portable implementation
> of
> >           : the MPI standard. This release has all MPI-2.1 functions and
> >           : features required by the standard with the exeption of support
> for
> >           : the "external32" portable I/O format.  The mpich2 binaries in
> this
> >           : RPM packages were configured to use the default process manager
> >           : 'MPD' using the default device 'ch3'. The ch3 device was
> configured
> >           : with support for the nemesis channel that allows for shared-
> memory
> >           : and TCP/IP sockets based communication.  This build also include
> >           : support for using '/usr/sbin/alternatives' and/or the 'module
> >           : environment' to select which MPI implementation to use when
> >           : multiple implementations are installed.
> > After install and configuring secret words and what not, we noticed mpif90
> didn't seem to exist. NONMEM is a FORTRAN compiled, so that's a must.
> mpich2version looks like it got built:
> > [usto-sapp-nmm02 7] ~ > mpich2version
> > MPICH2 Version:         1.2.1p1
> > MPICH2 Release date:    Unknown, built on Wed Aug 18 16:08:05 UTC 2010
> > MPICH2 Device:          ch3:nemesis
> > MPICH2 configure:       --build=x86_64-redhat-linux-gnu --host=x86_64-
> redhat-linux-gnu --target=x86_64-redhat-linux-gnu --program-prefix= --
> prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --
> sysconfdir=/etc --datadir=/usr/share --includedir=/usr/include --
> libdir=/usr/lib64 --libexecdir=/usr/libexec --localstatedir=/var --
> sharedstatedir=/usr/com --mandir=/usr/share/man --infodir=/usr/share/info --
> enable-sharedlibs=gcc --enable-f90 --with-device=ch3:nemesis --
> sysconfdir=/etc/mpich2-x86_64 --includedir=/usr/include/mpich2-x86_64 --
> libdir=/usr/lib64/mpich2/lib --datadir=/usr/share/mpich2 --
> mandir=/usr/share/man/mpich2 --docdir=/usr/share/mpich2/doc --
> htmldir=/usr/share/mpich2/doc --with-java=/etc/alternatives/java_sdk
> F90=gfortran F77=gfortran CFLAGS=-m64 -O2 -fPIC CXXFLAGS=-m64 -O2 -fPIC
> F90FLAGS=-m64 -O2 -fPIC FFLAGS=-m64 -O2 -fPIC LDFLAGS=-Wl,-z,noexecstack
> MPICH2LIB_CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -
> fstack-protector --param=
>  ss
> > p-buffer-size=4 -m64 -mtune=generic MPICH2LIB_CXXFLAGS=-O2 -g -pipe -Wall -
> Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-
> size=4 -m64 -mtune=generic MPICH2LIB_F90FLAGS=-O2 -g -pipe -Wall -Wp,-
> D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -
> m64 -mtune=generic MPICH2LIB_FFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2
> -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic
> > MPICH2 CC:      gcc -m64 -O2 -fPIC -O2 -g -pipe -Wall -Wp,-
> m64 -mtune=generic -O2
> > MPICH2 CXX:     c++ -m64 -O2 -fPIC -O2 -g -pipe -Wall -Wp,-
> > MPICH2 F77:     gfortran -m64 -O2 -fPIC -O2 -g -pipe -Wall -Wp,-
> > MPICH2 F90:     gfortran -m64 -O2 -fPIC -O2 -g -pipe -Wall -Wp,-
> > But which mpif90 returns nothing and locate mpif90 only returns
> documentation.
> > [usto-sapp-nmm02 10] ~ > locate mpif90
> > /etc/alternatives/mpif90-man
> > /etc/mpich2-x86_64/mpif90.conf
> > /usr/share/man/man1/mpif90.1.gz
> > /usr/share/man/mpich2/man1/mpif90.1.gz
> > Any next steps would be appreciated!
> > PKDM IS Liaison
