[mpich-discuss] questions about cpu assign in windows
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Aug 5 10:34:09 CDT 2011
When your launch your MPI job, the process manager creates the MPI processes and the OS schedules these processes (By default processes are not bound to a core. The OS scheduling policy decides on it).
You can explicitly specify the binding policy using the "-binding" option of mpiexec on Windows (Refer to Section 9.6 of the Windows developers guide available at http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs for details).
Jayesh
----- Original Message -----
To: "mpich-discuss" <mpich-discuss at mcs.anl.gov>
Sent: Friday, August 5, 2011 12:03:11 AM
Subject: [mpich-discuss] questions about cpu assign in windows
hi
I am new to MPICH, now I face up with a problem.
I can't get the info. about which cpu ( or computer, node) does the process excute in when I use mpi.
I read the material about it , it says "MPI is a clean interface , didn't offer the resource management interface" so can I think it means that ,if I want to know the info as I said before, I need to install another software to gain my ends.
My operating system is WindowsXP, so I can't use taskset. Can you give me some advices?
thanks
Yao
mpich-discuss mailing list
