[mpich-discuss] Duplicated symbols with GCC 4.4.4 on RHEL 5.5 (1.4rc2)
Pavan Balaji
balaji at mcs.anl.gov
Fri Apr 29 16:40:51 CDT 2011
I believe this was fixed by the hwloc upgrade after 1.4rc2. Can you try
out the nightly snapshot to make sure?
-- Pavan
On 04/29/2011 01:28 PM, Yauheni Zelenko wrote:
> Hi!
> I have duplicated symbols problem with building 1.4rc2 on Red Hat Enterprise Linux Client release 5.5 (Tikanga) with GCC 4.4.4 without --enable-strict.
> Next configuration is fine
> ./configure --prefix=${InstallDir} \
> --with-pm=hydra --with-device=ch3:nemesis \
> --disable-chekpointing \
> --enable-strict --enable-fast=O3 \
> --disable-f77 --disable-fc \
> CC=/grid/common/pkgs/gcc/v4.4.4/bin/gcc CFLAGS="-m32 -fPIC" \
> CPP=/grid/common/pkgs/gcc/v4.4.4/bin/cpp \
> CXX=/grid/common/pkgs/gcc/v4.4.4/bin/g++ CXXFLAGS="-m32 -fPIC" \
> CXXCPP=/grid/common/pkgs/gcc/v4.4.4/bin/cpp
> But:
> --enable-fast=O3 \
> Produce multiple errors like:
> /home/zelenko/Installs/mpich2-dev/src/src/pm/hydra/tools/bind/hwloc/hwloc/src/.libs/libhwloc_embedded.a(bind.o): In function `pthread_equal':
> bind.c:(.text+0x0): multiple definition of `pthread_equal'
> /home/zelenko/Installs/mpich2-dev/src/src/pm/hydra/tools/bind/hwloc/hwloc/src/.libs/libhwloc_embedded.a(topology.o):topology.c:(.text+0x480): first defined here
> /home/zelenko/Installs/mpich2-dev/src/src/pm/hydra/tools/bind/hwloc/hwloc/src/.libs/libhwloc_embedded.a(bind.o): In function `gnu_dev_major':
> bind.c:(.text+0x20): multiple definition of `gnu_dev_major'
> /home/zelenko/Installs/mpich2-dev/src/src/pm/hydra/tools/bind/hwloc/hwloc/src/.libs/libhwloc_embedded.a(topology.o):topology.c:(.text+0x0): first defined here
> /home/zelenko/Installs/mpich2-dev/src/src/pm/hydra/tools/bind/hwloc/hwloc/src/.libs/libhwloc_embedded.a(bind.o): In function `gnu_dev_minor':
> bind.c:(.text+0x40): multiple definition of `gnu_dev_minor'
> /home/zelenko/Installs/mpich2-dev/src/src/pm/hydra/tools/bind/hwloc/hwloc/src/.libs/libhwloc_embedded.a(topology.o):topology.c:(.text+0x20): first defined here
> /home/zelenko/Installs/mpich2-dev/src/src/pm/hydra/tools/bind/hwloc/hwloc/src/.libs/libhwloc_embedded.a(bind.o): In function `gnu_dev_makedev':
> bind.c:(.text+0x80): multiple definition of `gnu_dev_makedev'
> Looks like all problematic symbols is defined as __inline in system headrers.
> Eugene.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
