[mpich-discuss] mpdlib.py warning
Dave Goodell goodell at mcs.anl.gov
Fri Apr 29 13:42:37 CDT 2011
Use an older python or a newer version of mpich2.  The latest versions of MPICH2 use the newer hydra process manager instead, deprecating mpd.  There exists some version of MPICH2 (>1.0.6) with an mpd that suppresses that warning, but I would recommend using hydra instead anyway.
http://wiki.mcs.anl.gov/mpich2/index.php/Frequently_Asked_Questions#Q:_I_don.27t_like_.3CWHATEVER.3E_about_mpd.2C_or_I.27m_having_a_problem_with_mpdboot.2C_can_you_fix_it.3F
-Dave
On Apr 29, 2011, at 1:33 PM CDT, Jain, Rohit wrote:
> While running my application with mpich2-1.06 & mpd, I see following warnings on a particular machine:
> Python 2.6
> /s/hpbrws9/mpich2/linux_x86_64/bin/mpdlib.py:8: DeprecationWarning: The popen2 module is deprecated.  Use the subprocess module.
>   import sys, os, signal, popen2, socket, select, inspect
> /s/hpbrws9/mpich2/linux_x86_64/bin/mpdlib.py:15: DeprecationWarning: the md5 module is deprecated; use hashlib instead
>   from  md5       import  new as md5new
> Is this something to worry about?
> Regards,
> Rohit
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
