[mpich-discuss] Possible setup problem
Darius Buntinas
buntinas at mcs.anl.gov
Mon Apr 25 15:32:11 CDT 2011
Sorry. Just run:
mpicc simple_test.c -o simple_test
If you needed to specify the full path for mpiexec, use the same path for mpicc. This will generate the executable called simple_test.
-d
On Apr 25, 2011, at 3:26 PM, Andy_Holland at URSCorp.com wrote:
> Darius,
> Thanks for your help with this. You'll have to forgive me though, I'm a Fortran programmer and I'm not exactly sure how to compile the program you sent me. I have gcc by the way.
> Thanks,
> Andy Holland
> Air Quality Modeler
> URS Corporation
> 1600 Perimeter Park Drive
> Suite 400
> Morrisville, NC 27560
> Direct: (303) 796-4694
> Cell: (919) 619-4218
> Fax: (919) 461-1415
> andy_holland at urscorp.com
> This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies.
> Darius Buntinas <buntinas at mcs.anl.gov>
> Sent by: mpich-discuss-bounces at mcs.anl.gov
> 04/25/2011 03:19 PM
> Please respond to
> mpich-discuss at mcs.anl.gov
> To
> cc
> Subject
> Re: [mpich-discuss] Possible setup problem
> OK, can you try the attached test program with the same number of processes and machine file, but also add the -l option to mpiexec (to label the lines of output with the rank).
> Thanks,
> -d
> [attachment "simple_test.c" deleted by Andy Holland/Denver/URSCorp]
> On Apr 25, 2011, at 2:00 PM, Andy_Holland at URSCorp.com wrote:
> > I've attached the log for running cpi using the same machinefile.
> > Thank you,
> > Andy Holland
> > Air Quality Modeler
> > URS Corporation
> > Suite 400
> > Fax: (919) 461-1415
> > 04/25/2011 02:51 PM
> > Please respond to
> > To
> > cc
> > Subject
> > Hi Andy,
> > Can you try running cpi from the examples directory of the MPICH2 source tree with the same number of processes and the same machine file? Let us know if that works, and, if not, send us the output, please.
> > Thanks,
> > -d
> > On Apr 25, 2011, at 1:30 PM, Andy_Holland at URSCorp.com wrote:
> > > It was suggested that I send out all the error messages. I've attached a log file from the model.
> > > Thank you,
> > > Andy Holland
> > > Air Quality Modeler
> > > URS Corporation
> > > Suite 400
> > > Fax: (919) 461-1415
> > > Dave Goodell <goodell at mcs.anl.gov>
> > > 04/25/2011 02:22 PM
> > > Please respond to
> > > To
> > > cc
> > > Subject
> > > On Apr 25, 2011, at 12:59 PM CDT, Andy_Holland at URSCorp.com wrote:
> > > > When I run from either machine using CPUs from both machines the run stops with many mpi messages. Below is the last message in the list:
> > > > main (/usr/local/mpich2-1.3.2p1/src/pm/hydra/ui/mpich/mpiexec.c:404): process manager error waiting for completion
> > > Can you send us all of the error messages? Typically the first error messages are the most useful/relevant; the last ones often are just messages announcing some sort of cleanup or secondary error caused by the original error.
> > > -Dave
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> > > <run.cctm.parallel.txt>_______________________________________________
> > <cpi_log.txt>_______________________________________________
