[mpich-discuss] Possible setup problem
Darius Buntinas buntinas at mcs.anl.gov
Mon Apr 25 13:51:59 CDT 2011
Hi Andy,
Can you try running cpi from the examples directory of the MPICH2 source tree with the same number of processes and the same machine file?  Let us know if that works, and, if not, send us the output, please.
-d
On Apr 25, 2011, at 1:30 PM, Andy_Holland at URSCorp.com wrote:
> It was suggested that I send out all the error messages.  I've attached a log file from the model.
> Thank you,
> Andy Holland
> Air Quality Modeler
> URS Corporation
> 1600 Perimeter Park Drive
> Suite 400
> Morrisville, NC 27560
> Direct: (303) 796-4694
> Cell: (919) 619-4218
> Fax: (919) 461-1415
> andy_holland at urscorp.com
> This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies.
> Dave Goodell <goodell at mcs.anl.gov>
> Sent by: mpich-discuss-bounces at mcs.anl.gov
> 04/25/2011 02:22 PM
> Please respond to
> mpich-discuss at mcs.anl.gov
> To
> cc
> Subject
> Re: [mpich-discuss] Possible setup problem
> On Apr 25, 2011, at 12:59 PM CDT, Andy_Holland at URSCorp.com wrote:
> > When I run from either machine using CPUs from both machines the run stops with many mpi messages.  Below is the last message in the list:
> > main (/usr/local/mpich2-1.3.2p1/src/pm/hydra/ui/mpich/mpiexec.c:404): process manager error waiting for completion
> Can you send us all of the error messages?  Typically the first error messages are the most useful/relevant; the last ones often are just messages announcing some sort of cleanup or secondary error caused by the original error.
> -Dave
> mpich-discuss mailing list
> <run.cctm.parallel.txt>_______________________________________________
