[mpich-discuss] about installation
Mandar Gurav mandarwce at gmail.com
Thu Apr 21 03:49:33 CDT 2011
Though this is not direct answer to your question, but did you tried this?
Open|SpeedShop (http://www.openspeedshop.org/wp/)
Instead of trying all the configuration and all, I will suggest to
have alook at this.
-- Mandar Gurav
On Thu, Apr 21, 2011 at 1:19 PM, Kaveri Zanje <kaveri.907 at gmail.com> wrote:
> I have install mpich2-1.3.2p1  with file system luster , testfs, ufs.
> I want to install valgrind for tracing MPI-IO call, but i am not able to
> install it .
> it is giving me following error
> Making all in mpi
> make[2]: Entering directory `/home1/stu2/valgrind-3.6.0/mpi'
> mpicc -g -O -fno-omit-frame-pointer -Wall -fpic -m64  -fpic -shared  -o
> libmpiwrap-amd64-linux.so libmpiwrap_amd64_linux_so-libmpiwrap.o
> /usr/bin/ld: /home/stu2/home1/mpich2-install/lib/libmpich.a(comm_rank.o):
> relocation R_X86_64_32 against `a local symbol' can not be used when making
> a shared object; recompile with -fPIC
> /home/stu2/home1/mpich2-install/lib/libmpich.a: could not read symbols: Bad
> value
> collect2: ld returned 1 exit statusut
> make[2]: *** [libmpiwrap-amd64-linux.so] Error 1
> make[2]: Leaving directory `/home1/stu2/valgrind-3.6.0/mpi'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home1/stu2/valgrind-3.6.0'
> make: *** [all] Error 2
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Mandar Gurav
http://www.mandargurav.org
