[mpich-discuss] Funky MPI_File_write_at Parameters
Ellis H. Wilson III
ellis at runnersroll.com
Tue Apr 12 09:01:05 CDT 2011
On 04/12/11 09:54, William Gropp wrote:
> The offset is likely 8 bytes, not 4 (it depends on the MPI
> implementation and file system environment), and the write buffer must
> be non-null unless a datatype with an absolute address is used. My
> guess is that the offset is 8 bytes, and that is throwing off the
> interpretation of the traceback.
Thanks a lot for your suggestion William. Ironically I was reading your
book (Using MPI, second edition) to try and figure this out this past
weekend.
I am using MPICH 1.0.7 and PVFS2 2.7.1. I think the crux of the problem
is in IOR, as it stores offset and count as long long int which is 8
bytes instead of MPICH's expected 4.
I'll investigate, thanks for your help!
ellis
