[mpich-discuss] Error with mpich2, hydra, sge
    Richard Jacobsen
    ramassa at ucdavis.edu
    Fri Apr  8 13:37:15 CDT 2011
I the MPIR_Init_Thread error was because the job was changing out of the
working directory.
After resolving that I had a few PE errors.  Here's the SGE PE that
seems to work well with MPICH2 1.3.2p1/Hydra:
qconf -sp hydra2
pe_name            hydra2
slots              9999
user_lists         NONE
xuser_lists        NONE
start_proc_args    /bin/true
stop_proc_args     /bin/true
allocation_rule    $fill_up
control_slaves     TRUE
job_is_first_task  TRUE
urgency_slots      min
accounting_summary FALSE
Thanks for all of the help,
Richard
On 04/08/2011 09:20 AM, Pavan Balaji wrote:
> On 04/07/2011 06:23 PM, Richard Jacobsen wrote:
>> I also just tried cutting a few things out of this users job script, and
>> now the mpiexec is running.  I'm going to see if I can isolate what
>> caused the error.
> I'm not so certain this has anything to do with Hydra. Can you try
> running the application without mpiexec? It will behave as if it was
> launched with a single process, but will not use hydra at all. I'm
> guessing that it will abort with the same error.
>  -- Pavan
