[mpich-discuss] 1.2.1p1 and Linux
    Hiatt, Dave M
    dave.m.hiatt at citi.com
    Thu Sep 30 11:05:44 CDT 2010
Roger that.  One more question if I may.  I assume that the rule still applies that a process, (not just a thread within the process that executed the MPI_INIT), but the full process which has done an MPI_FINALIZE, still cannot do a subsequent MPI_INIT, correct?  To restart with a reduced collective, the process that had the failure must terminate complete, and a new process must start (or be forked) before a new MPI_INIT can be done on what would be a reduced collective presumably.
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius Buntinas
Sent: Thursday, September 30, 2010 10:56 AM
Subject: Re: [mpich-discuss] 1.2.1p1 and Linux
The 1.3 has checkpointing <http://wiki.mcs.anl.gov/mpich2/index.php/Checkpointing> and has improved tolerance for process and communication failures (using TCP).  If a process sets the error handler to MPI_ERRORS_RETURN then in the event of a communication failure, e.g., if a process dies and another process tries to send a message to it, an error code will be returned to the application, and communication with other processes will still be possible.  However, collectives are problematic with failed processes.  The behavior of collectives with failed processes is not defined by the standard.  Currently such a collective operation may fail, succeed or hang for different processes in the communicator.  We along with the MPI Forum are working on these issues.
-d
On Sep 29, 2010, at 5:39 PM, Hiatt, Dave M wrote:
> Yes, we need to go to Hydra anyway.
> Speaking of 1.3, that has fixes for fault tolerance doesn't it?  Is there documentation available now for how to implement it from the application's perspective?
> Thanks
> dave
> Sent: Wednesday, September 29, 2010 2:46 PM
> OK, good luck :-).  You could try the 1.3 release candidate, or use hydra.
> -d
> On Sep 29, 2010, at 2:42 PM, Hiatt, Dave M wrote:
>> Can't get MPD ring to start.  Having to drop back to backup systems because of hardware failure on RHEL 5 grid, things were running fine there.  This is kind of a fire drill situation, so there could be a lot of  reasons for this that are totally our fault and are configuration for sure and thought it should work.  Just wanted the reassurance to avoid a pie in the face before investing much time in chasing this problem down.  Thanks
>> Sent: Wednesday, September 29, 2010 2:28 PM
>> It should.  What issues are you seeing?
>> -d
>> On Sep 29, 2010, at 2:23 PM, Hiatt, Dave M wrote:
>>> 1.2.1p1 should function on RHEL 4.x should it not?
>>> "With sufficient thrust pigs can fly, but it is not necessarily a good idea"
>>> Dave M. Hiatt
>>> Director, Risk Analytics
>>> CitiMortgage
>>> 1000 Technology Drive
>>> O'Fallon, MO 63368-2240
>>> Telephone:  636-261-1408
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
