[mpich-discuss] launch failed when debugging i VS2008, 32bit application on 64 bit platform, on W7
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Sep 24 10:46:55 CDT 2010
Can you provide us some more details on your debug setup (eg: Is "apc665" the localhost ? etc)?
Do you get the same error if you try to debug cpi.exe provided with the MPICH2 installation (c:\program files\MPICH2\examples\cpi.exe)?
Jayesh
----- Original Message -----
From: "Iris Pernille Lohmann" <ipl at dhigroup.com>
Sent: Friday, September 24, 2010 8:27:40 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] launch failed when debugging i VS2008, 32bit application on 64 bit platform, on W7
Hi Jayesh,
Thanks a lot for your quick reply!
Yes, I tried also with the full path for the .in file (it is the same as the working dir) but no success.
I have used the MPI Cluster Debugger before, on windows vista 32 bit. When I reinstalled the Visual Studio 2008 on the windows7 64 bit machine, is it then the same debugger - does it work on both 32- and 64 bit code? Could it be the mpishim version? Or could it have something to do with the location of the Debug directories? I saw something about that in another ticket....I guess my understanding of how the debugger works is quite limited - I just use it!
Best regards,
Iris
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: 23. september 2010 17:54
Cc: Iris Pernille Lohmann
Have you used the MPI cluster debugger before for debugging MPI applications built with MPICH2 ?
Jayesh
Sent: Thursday, September 23, 2010 7:15:10 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] launch failed when debugging i VS2008, 32bit application on 64 bit platform, on W7
Dear list members,
I recently changed to Windows7 64 bit platform.
I reinstalled VisualStudio 2008 and SP1, along with IntelVisualFortran.
I also reinstalled MPICH2 for 32 bit windows, because the mpi-application I want to debug is 32 bit.
I have no trouble compiling and running the resulting executable outside VS2008.
But when I want to debug in VS2008, I get an error. It used to work on 32 bit Windows Vista.
This is the error notice, which comes for both processes (with my comments in <>):
Launch failed: CreateProcess (C:\Windows\System32\mpishim.exe APCxxx {<a long number>} C:\Work\ns3\bin\ns3hs.exe caseA_reg1.in on ‘apc665’ failed, error 2 – The system cannot find the file specified.
The settings in VS on the property page for debugging is:
Configuration: Active (Debug)
Platform: Active (Win32)
Debugger to launch: MPI Cluster Debugger
MPIRun Command: C:\Program Files (x86)\MPICH2\bin\mpiexec.exe
MPIRun Arguments: -n 2
MPIRun Working Directory: C:\projects\11802389-1_SeabedWindfarmInteraction\test_new_user\wave_3D_stokes\caseA_reg1_channel\input
Application Command: C:\Work\ns3\bin\ns3hs.exe
Application Arguments: caseA_reg1.in
MPIShim Location: C:\Windows\System32\mpishim.exe
MPI network security mode: Accept connections from any address
MPI network filter: <empty>
Debugger type: Auto
I have searched for tickets of the same kind but haven’t found any. Do you know if there is any way I can get information on which file that can’t be found? Or what the problem is? Do I have some wrong files, or do I miss a setting in VS? Remember that the program compiles and can be run outside VS2008.
(I have checked that the paths and file-names are ok!)
I will be happy for any suggestion!
Many thanks in advance,
Iris
mpich-discuss mailing list
