[mpich-discuss] SGE & Hydra Problem
    Ursula Winkler
    ursula.winkler at uni-graz.at
    Wed Sep 22 08:38:49 CDT 2010
Pavan Balaji schrieb:
> Great. I'll commit this in.
> Based on Reuti's previous message, I remembered that qrsh can be configured to use ssh or rsh internally as well. With older openssh versions, there was a problem when the stdin socket is closed before calling ssh. Newer openssh versions seem to have fixed that. So, we had a work around in Hydra for ssh to handle this case, but only for ssh. I just extended that workaround to be used for sge and rsh as well.
> So my guess is that the second cluster has a newer ssh version while the first cluster has an older ssh version and qrsh uses ssh internally.
Sounds plausibel. But both have the same openssh (same OS, same patch
level).
Ursula
