[mpich-discuss] SGE & Hydra Problem
Pavan Balaji
balaji at mcs.anl.gov
Wed Sep 22 07:06:06 CDT 2010
----- "Ursula Winkler" <ursula.winkler at uni-graz.at> wrote:
> > Ok, just to confirm, if nodes X and Y are both in the
> $TMPDIR/machines file, you are running the qrsh command from node X to
> node Y, correct?
> yes
Very surprising, given that this works when used from within Hydra. Without running qrsh independently (without Hydra), it's hard to figure out what's going wrong.
Reuti: any ideas on why this is happening?
Below is something I noticed, though that might or might not be a problem.
> The cluster on which it works:
> SGE_RSH_COMMAND=/installadmin/sge/utilbin/lx24-amd64/rsh
This doesn't seem to be set on the cluster where mpiexec doesn't work. Is this supposed to be the case?
-- Pavan
