[mpich-discuss] SGE & Hydra Problem
Ursula Winkler
ursula.winkler at uni-graz.at
Wed Sep 15 04:08:31 CDT 2010
Pavan Balaji schrieb:
> Did it not give any output before failing?
no, unfortunately not.
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
>>> I'm assuming the application still hung at this point and you had to
>> kill it?
>> No, I didn't have to kill it. It finished (or timed out) by itself.
>>> Are you not running this command within an SGE job script? The qrsh
>> command should be run from b79, not from b00.
>> Ok, everything clear :-)
>> But the command "/installadmin/sge/bin/lx24-amd64/qrsh -inherit -V
>> b56
>> /installadmin/mpich2/test/intel/bin/hydra_pmi_proxy --control-port
>> b73:52298
>> --debug --demux poll --pgid 0 --enable-stdin 1 --proxy-id 1" run in a
>> SGE job
>> script from b46 gives the same error: "error: executing task of job
>> 158279 failed:"
>> Ursula
