[mpich-discuss] SGE & Hydra Problem
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Sep 14 14:50:47 CDT 2010
 If you need to use SMPD you will need to recompile your code (AFAIK you won't need to recompile your code for other PMs).
Jayesh
----- Original Message -----
To: "Lista Mpich" <mpich-discuss at mcs.anl.gov>
Sent: Tuesday, September 14, 2010 2:42:30 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] SGE & Hydra Problem
Am 14.09.2010 um 20:10 schrieb Pavan Balaji:
> On 09/14/2010 10:10 AM, Reuti wrote:
>> did you also recompile all applications with the latest version of
>> MPICH2, so that binaries and mpiexec are from the same version?
> Actually, you don't need to recompile the application at all. If the
> application was compiled with any version of any MPICH2 derivative,
> it's sufficient.
thanks for clarification - I wasn't aware of it. In the past I
struggled a little bit with the different compilation methods of
MPICH2 (mpd/smpd/smpd with rsh/gforker) and my conclusion was, they
must always match the compilation of all involved parts.
BTW: will the other methods be dropped over time, when Hydra is the to
be used one in the future?
-- Reuti
> -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
mpich-discuss mailing list
