[mpich-discuss] SGE & Hydra Problem
    Ursula Winkler
    ursula.winkler at uni-graz.at
    Tue Sep 14 02:37:33 CDT 2010
thank's for your answer.
> which version of SGE are you running - using port 536 was used in
> former times, and nowadays the official ports are 6444 and 6445.
SGE 6.1. The port number is ok.
>>     error: getting configuration: unable to contact qmaster using
>> port 536 on host "b00"
>>     error:
>>     Cannot get configuration from qmaster.
> This looks more like a network problem, and unrelated to SGE or
> MPICH2. Dou you have any firewall on the machines? Other applications
> run across the nodes? AFAICS below, SGE is using rsh, and not the
> default -builtin- of the newer versions of SGE (there would be no rsh/
> rshd any longer) - nevertheless, your setup should work.
Within the cluster there is no firewall. There are no other applications
running
accross the nodes. The setup works for MPICH1, and MPICH2 smpd, just with
Hydra are the problems. I also can not see any network problems.
The more mysterious, Hydra works fine on another cluster (with same OS
and SGE).
Hmm.
> In principle this looks nice, as all the processes are bound to the
> sgeexecd. This is what I tried to achieve in:
> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-August/007678.html
yes, the tight integration works fine! (I'd be happy if it were the same
with mvapich.)
> But in the meantime, SGE is now supported out-of-the-box by MPICH2.
> Can just issue a plain "mpiexec ./cpitest.x". With a proper request of
> a PE in SGE (/bin/true is sufficient for the start/stop_proc_args),
> Hydra should get the number of cores and nodes automatically (in
> 1.3b1, which you are referring to).
I tried it out on the cluster where hydra performs:  it  works perfectly -
thank you.
Just the hydra problem on the other cluster remains and I don't have any
ideas why.
Ursula
