[mpich-discuss] Problem while running example program Cpi with	morethan 1 task
    Thejna Tharammal
    ttharammal at marum.de
    Thu Sep  9 10:54:56 CDT 2010
 Hi Pavan,
This is the result of the test you suggested(1.3b,nemesis,hydra),
 second one without the env mpich_no_local,(it gives the same error for >1
tasks on one node)
-bash-3.2$ mpiexec -n 7 -env MPICH_NO_LOCAL=1 ./cpi
Process 0 of 7 is on k1
Process 1 of 7 is on k1
Process 2 of 7 is on k1
Process 3 of 7 is on k1
Process 5 of 7 is on k1
Process 6 of 7 is on k1
Process 4 of 7 is on k1
pi is approximately 3.1415926544231239, Error is 0.0000000008333307
wall clock time = 0.001221
-bash-3.2$ mpiexec -n 7 ./cpi
wall clock time = 0.000221
APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
Thejna
----------------original message-----------------
To: "Thejna Tharammal" ttharammal at marum.de
CC: mpich-discuss at mcs.anl.gov
Date: Wed, 08 Sep 2010 11:47:16 -0500
> Thejna,
> From the output it looks like all the processes finalized fine, but
> aborted after that. Also, it looks like you have again gone back to the
> multi-node case from the single node case which was also failing and
> easier to debug. What's the strange output you see with the -verbose
> option? The output seems fine to me.
> Thanks for trying out ch3:sock instead of the default ch3:nemesis; I was
> about to ask you to try that next.
> Can you go back to ch3:nemesis (default) and 1.3b1, and try to run the
> application with the environment MPICH_NO_LOCAL set to 1. Let's just use
> a single node for the time being:
> % mpiexec -n 7 -env MPICH_NO_LOCAL=1 ./cpi
> -- Pavan
> On 09/08/2010 09:48 AM, Thejna Tharammal wrote:
>> Hi Pavan,
>> Thank you for the reply,
>> I ran them from k1 itself,
>> Now I went back one step and configured 1.2.1p1 and 1.3b1 with
>> --with-device=ch3:sock option, then no errors are showing up with cpi (I
>> used hydra for both)
>> I am attaching the files - results , (with 6 hosts,48 processes)
>> But when I use -verbose option I see some strange messages.
>> I used mpiexec -n 48 ./cpi&
>> mpiexec -verbose -n 48 ./cpi
>> Thanks,
>> Thejna
>> From: "Pavan Balaji" balaji at mcs.anl.gov
>> Date: Tue, 07 Sep 2010 20:33:00 -0500
>>> Sorry for the delay in getting back to this.
>>> On 09/03/2010 07:43 AM, Thejna Tharammal wrote:
>>>> Ok, I tried that,
>>>> No.of hosts 1:
>>>> 0.0000000008333307
>>>> wall clock time = 0.000198
>>>> 15)
>>> It looks like even on node is having problems. Are you executing the
>>> mpiexec from k1? Can you try executing it from k1?
>>> Thanks,
>>> -- Pavan
>>> Pavan Balaji
>>> http://www.mcs.anl.gov/~balaji
> Pavan Balaji
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100909/bd4aca4b/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100909/bd4aca4b/attachment-0003.obj>
