[mpich-discuss] MPICH2 trunk build - configure scripts missing because "configure in ./src/mpi/romio contains unresolved PAC macros"
Jeff Hammond
jhammond at mcs.anl.gov
Tue Sep 7 11:08:59 CDT 2010
I did a fresh checkout of the MPICH2 trunk, invoked
"./maint/updatefiles" (see below) then tried to configure (see below).
The configure step failed for rather obvious reasons. The relavant
error from the updatefiles step is "configure in ./src/mpi/romio
contains unresolved PAC macros". I had no trouble building MPICH2
trunk using these steps as recently as 2 days ago, if I remember
correctly.
Jeff
jeff at localhost:/software/mpich/mpich2-trunk> ./maint/updatefiles
## Checking user environment
Verifying the location of updatefiles... done
Checking for svn checkout errors... done
Checking if autotools are in the same location... yes, all in /usr
Checking for autoconf version... 2.63
Checking for automake version... >= 1.11
Checking for libtool version... >= 2.2.6
Checking for UNIX find... done
Checking if xargs accepts -r... accepted
## Autogenerating required files
Updating the README... done
Creating src/pm/smpd/smpd_version.h... done
Building Fortran 77 interface... done
Building Fortran 90 interface... done
Building C++ interface... done
Extracting error messages... done
===> WARNING: There are unused error message texts in
src/mpi/errhan/errnames.txt
===> WARNING: See the file unusederr.txt for the complete list
Initiating building required scripts
checking for perl... /usr/bin/perl
configure: creating ./config.status
config.status: creating simplemake
config.status: creating checkbuilds
config.status: creating getcoverage
config.status: creating genstates
config.status: creating clmake
config.status: creating f77tof90
config.status: creating extractstrings
config.status: creating extractstates
config.status: creating extractfixme
config.status: creating createcoverage
config.status: executing default-1 commands
Done building required scripts
Creating the enumeration of logging states into
src/include/mpiallstates.h... done
Generating parameter handling code... done
Checking if simplemake is created correctly... done
Create or update the Fortran 90 tests derived from the Fortran 77 tests... done
## Generating configure in simplemake directories
Initiating simplemake
libdir{${MPILIBNAME}} = ROOTDIR/lib
Shell variable MPID_THREAD_OUTPUT_FILES will not be added to the list
of known autoconf files for src/mpid/ch3.
Sourcefile src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_net_array.c
does not exist.
simplemake is assuming that this file will be created by the configure step
in the build directory
Warning: header file mpidconf.h.in or mpidconf.h.in.in not found in
src/mpid/globus/
of known autoconf files for src/mpid/dcmfd.
Shell variable FILE will not be added to the list
Skipping generation of rule for qdemo because Makefile.sm already contains one
Skipping generation of rule for tvtest because Makefile.sm already contains one
Replacing last config dir with ../../..
Warning: source file checksizes.c or checksizes.c.in not found in
test/mpi/f77/init/
Warning: source file ctypesfromc.c or ctypesfromc.c.in not found in
test/mpi/f90/ext/
test/mpi/f90/init/
Done running simplemake
Generating configure scripts
Found ./src/mpi/romio/configure.in; executing make configure target
jeff at localhost:/software/mpich/mpich2-trunk> ./configure CC=gcc-4.5
CXX=g++-4.5 F77=gfortran-4.5 FC=gfortran-4.5
--prefix=/software/mpich/mpich2-trunk-gnu45-build
--with-thread-package=pthreads --enable-threads=default --enable-f77
--enable-f90 --enable-cxx --enable-smpcoll --enable-mpe
--with-pm=hydra
Configuring MPICH2 version 1.3rc1 with 'CC=gcc-4.5' 'CXX=g++-4.5'
'F77=gfortran-4.5' 'FC=gfortran-4.5'
'--prefix=/software/mpich/mpich2-trunk-gnu45-build'
'--with-thread-package=pthreads' '--enable-threads=default'
'--enable-f77' '--enable-f90' '--enable-cxx' '--enable-smpcoll'
'--enable-mpe' '--with-pm=hydra'
Running on system: Linux localhost 2.6.27.48-0.1-default #1 SMP
2010-07-05 22:20:39 +0200 x86_64 x86_64 x86_64 GNU/Linux
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc-4.5 accepts -g... yes
checking for gcc-4.5 option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc-4.5 -E
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for grep that handles long lines and -e... /usr/bin/grep
checking for fgrep... /usr/bin/grep -F
Executing mpich2prereq in /software/mpich/mpich2-trunk/src/mpid/ch3 with
/software/mpich/mpich2-trunk/src/mpid/ch3/channels/nemesis
configure: ===== configuring src/mpl =====
configure: WARNING: /software/mpich/mpich2-trunk/src/mpl/configure
does not exist
configure: ===== done with src/mpl configure =====
configure: ===== configuring src/openpa =====
configure: WARNING: /software/mpich/mpich2-trunk/src/openpa/configure
does not exist
configure: ===== done with src/openpa configure =====
configure: WARNING: pm hydra has no configure
configure: error: Aborting configure because an error was seen in the
selection of process managers
Jeff Hammond
Argonne Leadership Computing Facility
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
