[mpich-discuss] cryptic (to me) error
SULLIVAN David (AREVA) David.Sullivan at areva.com
Fri Sep 3 13:10:07 CDT 2010
No it is not. I have copied everything to each node in the same
location.
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
Sent: Friday, September 03, 2010 2:03 PM
Subject: Re: [mpich-discuss] cryptic (to me) error
The test suite directory must be on a shared filesystem because mpiexec
does not stage executables for you.
-Dave
On Sep 3, 2010, at 1:02 PM CDT, SULLIVAN David (AREVA) wrote:
> Oh, Well I left it and every test results in...
> Unexpected output in attrend: [proxy:0:1 at porthos] HYDU_create_process
> (./utils/l
> aunch/launch.c:70): execvp error on file ./attrend (No such file or
> directory)
> (./utils/l
> directory)
> Unexpected output in attrend: [mpiexec at aramis] HYDT_dmx_deregister_fd
> (./tools/demux/demux.c:142): could not find fd to deregister: -2
> HYD_pmcd_pmiserv_cleanup
> (./pm/pmiserv/pmiserv_cb.c:398): error deregistering fd Unexpected
> output in attrend: APPLICATION TERMINATED WITH THE EXIT
> STRING: Hangup (signal 1)
> Program attrend exited without No Errors Unexpected output in
> attrend2: [proxy:0:1 at porthos] HYDU_create_process
> (./utils/launch/launch.c:70): execvp error on file ./attrend2 (No such
> file or directory) Unexpected output in attrend2: [proxy:0:1 at porthos]
> HYDU_create_process
> file or directory) Unexpected output in attrend2: [mpiexec at aramis]
> output in attrend2: APPLICATION TERMINATED WITH THE EXIT
> Program attrend2 exited without No Errors
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius
> Buntinas
> Sent: Friday, September 03, 2010 1:45 PM
> The tests run quietly, unless there's an error.  Set VERBOSE=1 to the
> command like to see each test running:
> HYDRA_HOST_FILE=XXX VERBOSE=1 make testing
> -d
> On Sep 3, 2010, at 12:40 PM, SULLIVAN David (AREVA) wrote:
>> Oh, Ok. Well it just hangs so I aborted. Checked each machine with
>> top
>> and neither are doing anything when it hangs. Attached is the screen
>> output.
>> Thanks again.
>> Dave
>> Sent: Friday, September 03, 2010 12:14 PM
>> Give the full path to your host file: /path/to/node_list
>> When the test script changes directories to the different test
>> directories, a relative path isn't correct anymore.
>> -Dave
>> On Sep 3, 2010, at 9:48 AM CDT, SULLIVAN David (AREVA) wrote:
>>> Wow, that made a difference. Not a good one. But a big one. I
>>> stopped
>>> the test since each process resulted in the attached errors. It
>>> looks
>>> like it is trying to access files that are not there to parse the
>>> HYDRA_HOST_FILE. I checked if there were there and it was just a
>>> permissions thing, but that was not the case.
>>> Dave
>>> Sent: Friday, September 03, 2010 10:36 AM
>>> I was unclear.  I meant to use HYDRA_HOST_FILE when running the
>>> MPICH2
>>> test suite in order to make it run across the same set of machines
>>> that your MCNP code runs on.
>>> -Dave
>>> On Sep 3, 2010, at 9:25 AM CDT, SULLIVAN David (AREVA) wrote:
>>>> Same result, mpi doesn't even get to call mcnp5.mpi. It just
>>>> returns
>>>> the
>>>> Fatal error in PMPI_Comm_dup: Other MPI error, error stack: error.
>>>> Goodell
>>>> Sent: Friday, September 03, 2010 10:21 AM
>>>> Try setting HYDRA_HOST_FILE=your_machine_file_here
>>>> This will make hydra act as though you passed "-f your
>>>> machine_file_here" to every mpiexec.
>>>> http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Ma
>>>> n
>>>> a
>>>> g
>>>> er
>>>> #Environment_Settings
>>>> -Dave
>>>> On Sep 3, 2010, at 5:00 AM CDT, SULLIVAN David (AREVA) wrote:
>>>>> I was wondering about that. Is there a configuration file that
>>>>> sets
>>>>> up
>>>> the cluster and defines which node to run on? Would that make the
>>>> issue any clearer?
>>>>> Thanks,
>>>>> Dave
>>>>> From: mpich-discuss-bounces at mcs.anl.gov on behalf of Rajeev Thakur
>>>>> Sent: Thu 9/2/2010 10:22 PM
>>>>> There might be some connection issues between the two machines.
>>>>> The
>>>> MPICH2 test suite that you ran with "make testing" probably ran on
>>>> a
>>>> single machine.
>>>>> On Sep 2, 2010, at 6:27 PM, SULLIVAN David (AREVA) wrote:
>>>>>> The error occurs immediately- I don't think it even starts the
>>>> executable. It does work on the single machine with 4 processes.
>>>>>> Thakur
>>>>>> Sent: Thu 9/2/2010 4:34 PM
>>>>>> Does it run with 2 processes on a single machine?
>>>>>> On Sep 2, 2010, at 2:38 PM, SULLIVAN David (AREVA) wrote:
>>>>>>> That fixed the compile. Thanks!
>>>>>>> The latest release does not fix the issues I am having though.
>>>>>>> Cpi
>>>>>>> works fine, the test suit is certainly improved (see summary.xml
>>>>>>> output) though when I try to use mcnp it still crashes in the
>>>>>>> same
>>>>>>> way (see
>>>>>>> error.txt)
>>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Anthony
>>>>>>> Chan
>>>>>>> Sent: Thursday, September 02, 2010 1:38 PM
>>>>>>> There is a bug in 1.3b1 about the option --enable-fc.  Since
>>>>>>> Fortran
>>>>>>> 90 is enabled by default, so remove the --enable-fc from your
>>>>>>> configure command and try again.  If there is error again, send
>>>>>>> us
>>>>>>> the configure output as you seen on your screen (See README)
>>>>>>> instead
>>>> of config.log.
>>>>>>> A.Chan
>>>>>>> ----- "SULLIVAN David (AREVA)" <David.Sullivan at areva.com> wrote:
>>>>>>>> Failure again.
>>>>>>>> The 1.3 beta version will not compile with Intel 10.1. It bombs
>>>>>>>> at
>>>>>>>> the
>>>>>>>> configuration script:
>>>>>>>> checking for Fortran flag needed to allow free-form source...
>>>>>>>> unknown
>>>>>>>> configure: WARNING: Fortran 90 test being disabled because the
>>>>>>>> /home/dfs/mpich2-1.3b1/bin/mpif90 compiler does not accept a
>>>>>>>> .f90
>>>>>>>> extension
>>>>>>>> configure: error: Fortran does not accept free-form source
>>>>>>>> configure: error: ./configure failed for test/mpi
>>>>>>>> I have attached to config.log
>>>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev
>>>>>>>> Thakur
>>>>>>>> Sent: Thursday, September 02, 2010 12:11 PM
>>>>>>>> Just try relinking with the new library at first.
>>>>>>>> Rajeev
>>>>>>>> On Sep 2, 2010, at 9:32 AM, SULLIVAN David (AREVA) wrote:
>>>>>>>>> I saw that there was a newer beta. I was really hoping to find
>>>>>>>>> I
>>>>>>>> just
>>>>>>>>> configured something incorrectly. Will this not require me to
>>>>>>>> re-build
>>>>>>>>> mcnp (the only program I run that uses mpi for parallel) if I
>>>>>>>>> change
>>>>>>>>> the mpi version? If so, this is a bit of a hardship, requiring
>>>>>>>>> codes
>>>>>>>>> to be revalidated. If not- I will try it in a second.
>>>>>>>>> Thanks,
>>>>>>>>> Dave
>>>>>>>> Goodell
>>>>>>>>> Sent: Thursday, September 02, 2010 10:27 AM
>>>>>>>>> Can you try the latest release (1.3b1) to see if that fixes
>>>>>>>>> the
>>>>>>>>> problems you are seeing with your application?
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.
>>>>>>>> p
>>>>>>>> h
>>>>>>>> p
>>>>>>>> ?s=
>>>>>>>>> do
>>>>>>>>> wnloads
>>>>>>>>> -Dave
>>>>>>>>> On Sep 2, 2010, at 9:15 AM CDT, SULLIVAN David (AREVA) wrote:
>>>>>>>>>> Another output file, hopefully of use.
>>>>>>>>>> Thanks again
>>>>>>>>>> Dave
>>>>>>>>>> SULLIVAN
>>>>>>>>>> David
>>>>>>>>>> (AREVA)
>>>>>>>>>> Sent: Thursday, September 02, 2010 8:20 AM
>>>>>>>>>> First my apologies for the delay in continuing this thread.
>>>>>>>>>> Unfortunately I have not resolved it so if I can indulge the
>>>>>>>>>> gurus
>>>>>>>>>> and
>>>>>>>>>> developers once again...
>>>>>>>>>> As suggested by Rajeev I ran the testing suit in the source
>>>>>>>> directory.
>>>>>>>>>> The output of errors, which are similar to what I was seeing
>>>>>>>>>> when
>>>>>>>>>> I
>>>>>>>>>> ran
>>>>>>>>>> mcnp5 (v. 1.40 and 1.51), is attached.
>>>>>>>>>> Any insights would be greatly appreciated,
>>>>>>>>>> Dave
>>>>>>>>>> Rajeev
>>>>>>>> Thakur
>>>>>>>>>> Sent: Wednesday, August 04, 2010 3:06 PM
>>>>>>>>>> Then one level above that directory (in the main MPICH2
>>>>>>>>>> source
>>>>>>>>>> directory), type make testing, which will run through the
>>>>>>>>>> entire
>>>>>>>>>> MPICH2 test suite.
>>>>>>>>>> Rajeev
>>>>>>>>>> On Aug 4, 2010, at 2:04 PM, SULLIVAN David (AREVA) wrote:
>>>>>>>>>>> Oh. That's  embarrassing. Yea. I have those examples. It
>>>>>>>>>>> runs
>>>>>>>> with
>>>>>>>>>>> no
>>>>>>>>>>> problems:
>>>>>>>>>>> [dfs at aramis examples]$ mpiexec -host aramis -n 4 ./cpi
>>>>>>>>>>> Process
>>>>>>>>>>> 2
>>>>>>>> of
>>>>>>>>>>> 4
>>>>>>>>>>> is on aramis Process 3 of 4 is on aramis Process 0 of 4 is
>>>>>>>>>>> on
>>>>>>>> aramis
>>>>>>>>>>> Process 1 of 4 is on aramis pi is approximately
>>>>>>>> 3.1415926544231239,
>>>>>>>>>>> Error is 0.0000000008333307 wall clock time = 0.000652
>>>>>>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus
>>>>>>>> Correa
>>>>>>>>>>> Sent: Wednesday, August 04, 2010 1:13 PM
>>>>>>>>>>> To: Mpich Discuss
>>>>>>>>>>> Hi David
>>>>>>>>>>> I think the "examples" dir is not copied to the installation
>>>>>>>>>> directory.
>>>>>>>>>>> You may find it where you decompressed the MPICH2 tarball,
>>>>>>>>>>> in
>>>>>>>>>>> case
>>>>>>>>>>> you
>>>>>>>>>>> installed it from source.
>>>>>>>>>>> At least, this is what I have here.
>>>>>>>>>>> Gus Correa
>>>>>>>>>>>> Yea, that always bothered me.  There is no such folder.
>>>>>>>>>>>> There are :
>>>>>>>>>>>> bin
>>>>>>>>>>>> etc
>>>>>>>>>>>> include
>>>>>>>>>>>> lib
>>>>>>>>>>>> sbin
>>>>>>>>>>>> share
>>>>>>>>>>>> The  only examples I found were in the  share folder,
>>>>>>>>>>>> where
>>>>>>>> there
>>>>>>>>>>> are
>>>>>>>>>>>> examples for collchk,  graphics and  logging.
>>>>>>>>>>>> Rajeev
>>>>>>>>>>>> Thakur
>>>>>>>>>>>> Sent: Wednesday, August 04, 2010 12:45 PM
>>>>>>>>>>>> Not cpilog. Can you run just cpi from the mpich2/examples
>>>>>>>> directory.
>>>>>>>>>>>> Rajeev
>>>>>>>>>>>> On Aug 4, 2010, at 11:37 AM, SULLIVAN David (AREVA) wrote:
>>>>>>>>>>>>> Rajeev,  Darius,
>>>>>>>>>>>>> Thanks for your response.
>>>>>>>>>>>>> cpi yields  the  following-
>>>>>>>>>>>>> [dfs at aramis examples_logging]$ mpiexec -host aramis -n 12
>>>>>>>> ./cpilog
>>>>>>>>>>>>> Process 0 running on aramis Process 2 running on aramis
>>>>>>>>>>>>> Process
>>>>>>>> 3
>>>>>>>>>>>>> running on aramis Process 1 running on aramis Process 6
>>>>>>>>>>>>> running
>>>>>>>> on
>>>>>>>>>>>>> aramis Process 7 running on aramis Process 8 running on
>>>>>>>>>>>>> aramis
>>>>>>>>>>>>> Process
>>>>>>>>>>>>> 4 running on aramis Process 5 running on aramis Process 9
>>>>>>>> running
>>>>>>>>>>>>> on
>>>>>>>>>>>>> aramis Process 10 running on aramis Process 11 running on
>>>>>>>>>>>>> aramis
>>>>>>>>>>>>> pi
>>>>>>>>>>>>> is
>>>>>>>>>>>>> approximately 3.1415926535898762, Error is
>>>>>>>>>>>>> 0.0000000000000830
>>>>>>>> wall
>>>>>>>>>>>>> clock time = 0.058131 Writing logfile....
>>>>>>>>>>>>> Enabling the Default clock synchronization...
>>>>>>>>>>>>> clog_merger.c:CLOG_Merger_init() -  Could not open file
>>>>>>>>>>>>> ./cpilog.clog2 for merging!
>>>>>>>>>>>>> Backtrace of the callstack at rank 0:
>>>>>>>>>>>>> At [0]: ./cpilog(CLOG_Util_abort+0x92)[0x456326]
>>>>>>>>>>>>> At [1]: ./cpilog(CLOG_Merger_init+0x11f)[0x45db7c]
>>>>>>>>>>>>> At [2]: ./cpilog(CLOG_Converge_init+0x8e)[0x45a691]
>>>>>>>>>>>>> At [3]: ./cpilog(MPE_Finish_log+0xea)[0x4560aa]
>>>>>>>>>>>>> At [4]: ./cpilog(MPI_Finalize+0x50c)[0x4268af]
>>>>>>>>>>>>> At [5]: ./cpilog(main+0x428)[0x415963]  At [6]:
>>>>>>>> /lib64/libc.so.6(__libc_start_main+0xf4)[0x3c1881d994]
>>>>>>>>>>>>> At [7]: ./cpilog[0x415449] application called
>>>>>>>>>>>>> MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>>>>>>>>>>> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated
>>>>>>>>>>>>> (signal
>>>>>>>>>>>>> 15)
>>>>>>>>>>>>> So  it looks like it works  with some issues.
>>>>>>>>>>>>> When does  it fail? Immediately
>>>>>>>>>>>>> Is there  a  bug? Many sucessfully use the aplication
>>>>>>>>>>>>> (MCNP5,
>>>>>>>>>>>>> from
>>>>>>>>>>>>> LANL) with  mpi,  so  think that  a  bug there is
> unlikely.
>>>>>>>>>>>>> Core files, unfortunately reveals some ignorance on my
> part.
>>>>>>>> Were
>>>>>>>>>>>>> exactly should I be looking for them?
>>>>>>>>>>>>> Thanks again,
>>>>>>>>>>>>> Dave
>>>>>>>>>>>>> Darius
>>>>>>>>>>>>> Buntinas
>>>>>>>>>>>>> Sent: Wednesday, August 04, 2010 12:19 PM
>>>>>>>>>>>>> This error message says that two processes terminated
>>>>>>>>>>>>> because
>>>>>>>> they
>>>>>>>>>>>>> were unable to communicate with another (or two other)
>>>> process.
>>>>>>>>>> It's
>>>>>>>>>>>>> possible that another process died, so the others got
>>>>>>>>>>>>> errors
>>>>>>>>>>>>> trying
>>>>>>>>>>>>> to
>>>>>>>>>>>>> communicate with them.  It's also possible that there is
>>>>>>>> something
>>>>>>>>>>>>> preventing some processes from communicating with each
>> other.
>>>>>>>>>>>>> Are you able to run cpi from the examples directory with
>>>>>>>>>>>>> 12
>>>>>>>>>>> processes?
>>>>>>>>>>>>> At what point in your code does this fail?  Are there any
>>>>>>>>>>>>> other
>>>>>>>>>>>>> communication operations before the MPI_Comm_dup?
>>>>>>>>>>>>> Enable core files (add "ulimit -c unlimited" to your
>>>>>>>>>>>>> .bashrc
>>>>>>>>>>>>> or
>>>>>>>>>>>>> .tcshrc) then run your app and look for core files.  If
>>>>>>>>>>>>> there
>>>>>>>>>>>>> is
>>>>>>>> a
>>>>>>>>>>>>> bug
>>>>>>>>>>>>> in your application that causes a process to die this
>>>>>>>>>>>>> might
>>>>>>>>>>>>> tell
>>>>>>>>>>>>> you
>>>>>>>>>>>>> which one and why.
>>>>>>>>>>>>> Let us know how this goes.
>>>>>>>>>>>>> -d
>>>>>>>>>>>>> On Aug 4, 2010, at 11:03 AM, SULLIVAN David (AREVA) wrote:
>>>>>>>>>>>>>> Since I have  had  no responses, is  there any other
>>>>>>>> additional
>>>>>>>>>>>>> information could I provide to solicit some direction for
>>>>>>>>>>>>> overcoming
>>>>>>>>>>>>> these latest string of mpi errors?
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Dave
>>>>>>>> SULLIVAN
>>>>>>>>>>>>>> David F (AREVA NP INC)
>>>>>>>>>>>>>> Sent: Friday, July 23, 2010 4:29 PM
>>>>>>>>>>>>>> Subject: [mpich-discuss] cryptic (to me) error
>>>>>>>>>>>>>> With my firewall issues firmly behind me, I have a new
>>>>>>>>>>>>>> problem
>>>>>>>>>>>>>> for
>>>>>>>>>>>>>> the
>>>>>>>>>>>>> collective wisdom. I am attempting to run a program to
>>>>>>>>>>>>> which
>>>>>>>>>>>>> the
>>>>>>>>>>>>> response is as follows:
>>>>>>>>>>>>>> [mcnp5_1-4 at athos ~]$ mpiexec -f nodes -n 12 mcnp5.mpi
>>>>>>>>>>>>>> i=TN04
>>>>>>>>>>>>>> o=TN04.o
>>>>>>>>>>>>>> Fatal error in MPI_Comm_dup: Other MPI error, error
stack:
>>>>>>>>>>>>>> MPI_Comm_dup(168).................:
>>>>>>>> MPI_Comm_dup(MPI_COMM_WORLD,
>>>>>>>>>>>>>> new_comm=0x7fff58edb450) failed
>>>>>>>>>>>>>> MPIR_Comm_copy(923)...............:
>>>>>>>>>>>>>> MPIR_Get_contextid(639)...........:
>>>>>>>>>>>>>> MPI_Allreduce(773)................:
>>>>>>>>>> MPI_Allreduce(sbuf=MPI_IN_PLACE,
>>>>>>>>>>>>> rbuf=0x7fff
>>>>>>>>>>>>> 58edb1a0, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD)
>>>>>>>>>>>>> failed
>>>>>>>>>>>>>> MPIR_Allreduce(228)...............:
>>>>>>>>>>>>>> MPIC_Send(41).....................:
>>>>>>>>>>>>>> MPIC_Wait(513)....................:
>>>>>>>>>>>>>> MPIDI_CH3I_Progress(150)..........:
>>>>>>>>>>>>>> MPID_nem_mpich2_blocking_recv(933):
>>>>>>>>>>>>>> MPID_nem_tcp_connpoll(1709).......: Communication error
>>>>>>>>>>>>>> Fatal
>>>>>>>>>>>>>> error
>>>>>>>>>>>>>> in
>>>>>>>>>>>>> new_comm=0x7fff
>>>>>>>>>>>>> 97dca620) failed
>>>>>>>>>>>>> rbuf=0x7fff
>>>>>>>>>>>>> 97dca370, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD)
>>>>>>>>>>>>> failed
>>>>>>>>>>>>>> MPIR_Allreduce(289)...............:
>>>>>>>>>>>>>> MPIC_Sendrecv(161)................:
>>>>>>>>>>>>>> MPID_nem_mpich2_blocking_recv(948):
>>>>>>>>>>>>>> Killed
>>>>>>>> by
>>>>>>>>>>>>>> signal 2.
>>>>>>>>>>>>>> Ctrl-C caught... cleaning up processes [mpiexec at athos]
>>>>>>>>>>>>>> HYDT_dmx_deregister_fd (./tools/demux/demux.c:142): could
>>>>>>>>>>>>>> not
>>>>>>>>>>>>>> find
>>>>>>>>>>>>>> fd
>>>>>>>>>>>>>> to deregister: -2 [mpiexec at athos]
>>>>>>>>>>>>>> (./pm/pmiserv/pmiserv_cb.c:401): error deregistering fd
>>>>>>>>>>>>>> [press
>>>>>>>>>>>>>> Ctrl-C
>>>>>>>>>>>>>> again to force abort] APPLICATION TERMINATED WITH THE
>>>>>>>>>>>>>> EXIT
>>>>>>>> STRING:
>>>>>>>>>>>>>> Killed (signal 9) [mcnp5_1-4 at athos ~]$ Any ideas?
>>>>>>>>>>>>>> Thanks in advance,
>>>>>>>>>>>>>> David Sullivan
>>>>>>>>>>>>>> AREVA NP INC
>>>>>>>>>>>>>> 400 Donald Lynch Boulevard Marlborough, MA, 01752
>>>>>>>>>>>>>> Phone: (508) 573-6721
>>>>>>>>>>>>>> Fax: (434) 382-5597
>>>>>>>>>>>>>> David.Sullivan at AREVA.com
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>>>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>>>>>>>> <summary.xml>_______________________________________________
>>>>>>> <summary.xml><error.txt>________________________________________
>>>>>>> _
>>>>>>> _
>>>>>>> _
>>>>>>> _
>>>>>>> ___
>>>>>> <winmail.dat>_______________________________________________
>>> <testing_screen.txt>_______________________________________________
