[mpich-discuss] cryptic (to me) error
    Dave Goodell
    goodell at mcs.anl.gov
    Fri Sep  3 11:14:20 CDT 2010
Give the full path to your host file: /path/to/node_list
When the test script changes directories to the different test directories, a relative path isn't correct anymore.
-Dave
On Sep 3, 2010, at 9:48 AM CDT, SULLIVAN David (AREVA) wrote:
> Wow, that made a difference. Not a good one. But a big one. I stopped
> the test since each process resulted in the attached errors. It looks
> like it is trying to access files that are not there to parse the
> HYDRA_HOST_FILE. I checked if there were there and it was just a
> permissions thing, but that was not the case.
> Dave
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
> Sent: Friday, September 03, 2010 10:36 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] cryptic (to me) error
> I was unclear.  I meant to use HYDRA_HOST_FILE when running the MPICH2
> test suite in order to make it run across the same set of machines that
> your MCNP code runs on.
> -Dave
> On Sep 3, 2010, at 9:25 AM CDT, SULLIVAN David (AREVA) wrote:
>> Same result, mpi doesn't even get to call mcnp5.mpi. It just returns
>> the
>> Fatal error in PMPI_Comm_dup: Other MPI error, error stack: error.
>> Sent: Friday, September 03, 2010 10:21 AM
>> Try setting HYDRA_HOST_FILE=your_machine_file_here
>> This will make hydra act as though you passed "-f your
>> machine_file_here" to every mpiexec.
>> http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manag
>> er
>> #Environment_Settings
>> -Dave
>> On Sep 3, 2010, at 5:00 AM CDT, SULLIVAN David (AREVA) wrote:
>>> I was wondering about that. Is there a configuration file that sets
>>> up
>> the cluster and defines which node to run on? Would that make the
>> issue any clearer?
>>> Thanks,
>>> Dave
>>> From: mpich-discuss-bounces at mcs.anl.gov on behalf of Rajeev Thakur
>>> Sent: Thu 9/2/2010 10:22 PM
>>> There might be some connection issues between the two machines. The
>> MPICH2 test suite that you ran with "make testing" probably ran on a
>> single machine.
>>> On Sep 2, 2010, at 6:27 PM, SULLIVAN David (AREVA) wrote:
>>>> The error occurs immediately- I don't think it even starts the
>> executable. It does work on the single machine with 4 processes.
>>>> Sent: Thu 9/2/2010 4:34 PM
>>>> Does it run with 2 processes on a single machine?
>>>> On Sep 2, 2010, at 2:38 PM, SULLIVAN David (AREVA) wrote:
>>>>> That fixed the compile. Thanks!
>>>>> The latest release does not fix the issues I am having though. Cpi
>>>>> works fine, the test suit is certainly improved (see summary.xml
>>>>> output) though when I try to use mcnp it still crashes in the same
>>>>> way (see
>>>>> error.txt)
>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Anthony
>>>>> Chan
>>>>> Sent: Thursday, September 02, 2010 1:38 PM
>>>>> There is a bug in 1.3b1 about the option --enable-fc.  Since
>>>>> Fortran
>>>>> 90 is enabled by default, so remove the --enable-fc from your
>>>>> configure command and try again.  If there is error again, send us
>>>>> the configure output as you seen on your screen (See README)
>>>>> instead
>> of config.log.
>>>>> A.Chan
>>>>> ----- "SULLIVAN David (AREVA)" <David.Sullivan at areva.com> wrote:
>>>>>> Failure again.
>>>>>> The 1.3 beta version will not compile with Intel 10.1. It bombs at
>>>>>> the
>>>>>> configuration script:
>>>>>> checking for Fortran flag needed to allow free-form source...
>>>>>> unknown
>>>>>> configure: WARNING: Fortran 90 test being disabled because the
>>>>>> /home/dfs/mpich2-1.3b1/bin/mpif90 compiler does not accept a .f90
>>>>>> extension
>>>>>> configure: error: Fortran does not accept free-form source
>>>>>> configure: error: ./configure failed for test/mpi
>>>>>> I have attached to config.log
>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev
>>>>>> Thakur
>>>>>> Sent: Thursday, September 02, 2010 12:11 PM
>>>>>> Just try relinking with the new library at first.
>>>>>> Rajeev
>>>>>> On Sep 2, 2010, at 9:32 AM, SULLIVAN David (AREVA) wrote:
>>>>>>> I saw that there was a newer beta. I was really hoping to find I
>>>>>> just
>>>>>>> configured something incorrectly. Will this not require me to
>>>>>> re-build
>>>>>>> mcnp (the only program I run that uses mpi for parallel) if I
>>>>>>> change
>>>>>>> the mpi version? If so, this is a bit of a hardship, requiring
>>>>>>> codes
>>>>>>> to be revalidated. If not- I will try it in a second.
>>>>>>> Thanks,
>>>>>>> Dave
>>>>>> Goodell
>>>>>>> Sent: Thursday, September 02, 2010 10:27 AM
>>>>>>> Can you try the latest release (1.3b1) to see if that fixes the
>>>>>>> problems you are seeing with your application?
>>>>>> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.ph
>>>>>> p
>>>>>> ?s=
>>>>>>> do
>>>>>>> wnloads
>>>>>>> -Dave
>>>>>>> On Sep 2, 2010, at 9:15 AM CDT, SULLIVAN David (AREVA) wrote:
>>>>>>>> Another output file, hopefully of use.
>>>>>>>> Thanks again
>>>>>>>> Dave
>>>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of SULLIVAN
>>>>>>>> David
>>>>>>>> (AREVA)
>>>>>>>> Sent: Thursday, September 02, 2010 8:20 AM
>>>>>>>> First my apologies for the delay in continuing this thread.
>>>>>>>> Unfortunately I have not resolved it so if I can indulge the
>>>>>>>> gurus
>>>>>>>> and
>>>>>>>> developers once again...
>>>>>>>> As suggested by Rajeev I ran the testing suit in the source
>>>>>> directory.
>>>>>>>> The output of errors, which are similar to what I was seeing
>>>>>>>> when
>>>>>>>> I
>>>>>>>> ran
>>>>>>>> mcnp5 (v. 1.40 and 1.51), is attached.
>>>>>>>> Any insights would be greatly appreciated,
>>>>>>>> Dave
>>>>>> Thakur
>>>>>>>> Sent: Wednesday, August 04, 2010 3:06 PM
>>>>>>>> Then one level above that directory (in the main MPICH2 source
>>>>>>>> directory), type make testing, which will run through the entire
>>>>>>>> MPICH2 test suite.
>>>>>>>> Rajeev
>>>>>>>> On Aug 4, 2010, at 2:04 PM, SULLIVAN David (AREVA) wrote:
>>>>>>>>> Oh. That's  embarrassing. Yea. I have those examples. It runs
>>>>>> with
>>>>>>>>> no
>>>>>>>>> problems:
>>>>>>>>> [dfs at aramis examples]$ mpiexec -host aramis -n 4 ./cpi Process
>>>>>>>>> 2
>>>>>> of
>>>>>>>>> 4
>>>>>>>>> is on aramis Process 3 of 4 is on aramis Process 0 of 4 is on
>>>>>> aramis
>>>>>>>>> Process 1 of 4 is on aramis pi is approximately
>>>>>> 3.1415926544231239,
>>>>>>>>> Error is 0.0000000008333307 wall clock time = 0.000652
>>>>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus
>>>>>> Correa
>>>>>>>>> Sent: Wednesday, August 04, 2010 1:13 PM
>>>>>>>>> To: Mpich Discuss
>>>>>>>>> Hi David
>>>>>>>>> I think the "examples" dir is not copied to the installation
>>>>>>>> directory.
>>>>>>>>> You may find it where you decompressed the MPICH2 tarball, in
>>>>>>>>> case
>>>>>>>>> you
>>>>>>>>> installed it from source.
>>>>>>>>> At least, this is what I have here.
>>>>>>>>> Gus Correa
>>>>>>>>>> Yea, that always bothered me.  There is no such folder.
>>>>>>>>>> There are :
>>>>>>>>>> bin
>>>>>>>>>> etc
>>>>>>>>>> include
>>>>>>>>>> lib
>>>>>>>>>> sbin
>>>>>>>>>> share
>>>>>>>>>> The  only examples I found were in the  share folder,  where
>>>>>> there
>>>>>>>>> are
>>>>>>>>>> examples for collchk,  graphics and  logging.
>>>>>>>>>> Thakur
>>>>>>>>>> Sent: Wednesday, August 04, 2010 12:45 PM
>>>>>>>>>> Not cpilog. Can you run just cpi from the mpich2/examples
>>>>>> directory.
>>>>>>>>>> Rajeev
>>>>>>>>>> On Aug 4, 2010, at 11:37 AM, SULLIVAN David (AREVA) wrote:
>>>>>>>>>>> Rajeev,  Darius,
>>>>>>>>>>> Thanks for your response.
>>>>>>>>>>> cpi yields  the  following-
>>>>>>>>>>> [dfs at aramis examples_logging]$ mpiexec -host aramis -n 12
>>>>>> ./cpilog
>>>>>>>>>>> Process 0 running on aramis Process 2 running on aramis
>>>>>>>>>>> Process
>>>>>> 3
>>>>>>>>>>> running on aramis Process 1 running on aramis Process 6
>>>>>>>>>>> running
>>>>>> on
>>>>>>>>>>> aramis Process 7 running on aramis Process 8 running on
>>>>>>>>>>> aramis
>>>>>>>>>>> Process
>>>>>>>>>>> 4 running on aramis Process 5 running on aramis Process 9
>>>>>> running
>>>>>>>>>>> on
>>>>>>>>>>> aramis Process 10 running on aramis Process 11 running on
>>>>>>>>>>> aramis
>>>>>>>>>>> pi
>>>>>>>>>>> is
>>>>>>>>>>> approximately 3.1415926535898762, Error is 0.0000000000000830
>>>>>> wall
>>>>>>>>>>> clock time = 0.058131 Writing logfile....
>>>>>>>>>>> Enabling the Default clock synchronization...
>>>>>>>>>>> clog_merger.c:CLOG_Merger_init() -  Could not open file
>>>>>>>>>>> ./cpilog.clog2 for merging!
>>>>>>>>>>> Backtrace of the callstack at rank 0:
>>>>>>>>>>> At [0]: ./cpilog(CLOG_Util_abort+0x92)[0x456326]
>>>>>>>>>>> At [1]: ./cpilog(CLOG_Merger_init+0x11f)[0x45db7c]
>>>>>>>>>>> At [2]: ./cpilog(CLOG_Converge_init+0x8e)[0x45a691]
>>>>>>>>>>> At [3]: ./cpilog(MPE_Finish_log+0xea)[0x4560aa]
>>>>>>>>>>> At [4]: ./cpilog(MPI_Finalize+0x50c)[0x4268af]
>>>>>>>>>>> At [5]: ./cpilog(main+0x428)[0x415963]  At [6]:
>>>>>> /lib64/libc.so.6(__libc_start_main+0xf4)[0x3c1881d994]
>>>>>>>>>>> At [7]: ./cpilog[0x415449]
>>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>>>>>>>>> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated
>>>>>>>>>>> (signal
>>>>>>>>>>> 15)
>>>>>>>>>>> So  it looks like it works  with some issues.
>>>>>>>>>>> When does  it fail? Immediately
>>>>>>>>>>> Is there  a  bug? Many sucessfully use the aplication (MCNP5,
>>>>>>>>>>> from
>>>>>>>>>>> LANL) with  mpi,  so  think that  a  bug there is  unlikely.
>>>>>>>>>>> Core files, unfortunately reveals some ignorance on my part.
>>>>>> Were
>>>>>>>>>>> exactly should I be looking for them?
>>>>>>>>>>> Thanks again,
>>>>>>>>>>> Dave
>>>>>>>>>>> Darius
>>>>>>>>>>> Buntinas
>>>>>>>>>>> Sent: Wednesday, August 04, 2010 12:19 PM
>>>>>>>>>>> This error message says that two processes terminated because
>>>>>> they
>>>>>>>>>>> were unable to communicate with another (or two other)
>> process.
>>>>>>>> It's
>>>>>>>>>>> possible that another process died, so the others got errors
>>>>>>>>>>> trying
>>>>>>>>>>> to
>>>>>>>>>>> communicate with them.  It's also possible that there is
>>>>>> something
>>>>>>>>>>> preventing some processes from communicating with each other.
>>>>>>>>>>> Are you able to run cpi from the examples directory with 12
>>>>>>>>> processes?
>>>>>>>>>>> At what point in your code does this fail?  Are there any
>>>>>>>>>>> other
>>>>>>>>>>> communication operations before the MPI_Comm_dup?
>>>>>>>>>>> Enable core files (add "ulimit -c unlimited" to your .bashrc
>>>>>>>>>>> or
>>>>>>>>>>> .tcshrc) then run your app and look for core files.  If there
>>>>>>>>>>> is
>>>>>> a
>>>>>>>>>>> bug
>>>>>>>>>>> in your application that causes a process to die this might
>>>>>>>>>>> tell
>>>>>>>>>>> you
>>>>>>>>>>> which one and why.
>>>>>>>>>>> Let us know how this goes.
>>>>>>>>>>> -d
>>>>>>>>>>> On Aug 4, 2010, at 11:03 AM, SULLIVAN David (AREVA) wrote:
>>>>>>>>>>>> Since I have  had  no responses, is  there any other
>>>>>> additional
>>>>>>>>>>> information could I provide to solicit some direction for
>>>>>>>>>>> overcoming
>>>>>>>>>>> these latest string of mpi errors?
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Dave
>>>>>> SULLIVAN
>>>>>>>>>>>> David F (AREVA NP INC)
>>>>>>>>>>>> Sent: Friday, July 23, 2010 4:29 PM
>>>>>>>>>>>> Subject: [mpich-discuss] cryptic (to me) error
>>>>>>>>>>>> With my firewall issues firmly behind me, I have a new
>>>>>>>>>>>> problem
>>>>>>>>>>>> for
>>>>>>>>>>>> the
>>>>>>>>>>> collective wisdom. I am attempting to run a program to which
>>>>>>>>>>> the
>>>>>>>>>>> response is as follows:
>>>>>>>>>>>> [mcnp5_1-4 at athos ~]$ mpiexec -f nodes -n 12 mcnp5.mpi i=TN04
>>>>>>>>>>>> o=TN04.o
>>>>>>>>>>>> Fatal error in MPI_Comm_dup: Other MPI error, error stack:
>>>>>>>>>>>> MPI_Comm_dup(168).................:
>>>>>> MPI_Comm_dup(MPI_COMM_WORLD,
>>>>>>>>>>>> new_comm=0x7fff58edb450) failed
>>>>>>>>>>>> MPIR_Comm_copy(923)...............:
>>>>>>>>>>>> MPIR_Get_contextid(639)...........:
>>>>>>>>>>>> MPI_Allreduce(773)................:
>>>>>>>> MPI_Allreduce(sbuf=MPI_IN_PLACE,
>>>>>>>>>>> rbuf=0x7fff
>>>>>>>>>>> 58edb1a0, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>>>>>>>>> MPIR_Allreduce(228)...............:
>>>>>>>>>>>> MPIC_Send(41).....................:
>>>>>>>>>>>> MPIC_Wait(513)....................:
>>>>>>>>>>>> MPIDI_CH3I_Progress(150)..........:
>>>>>>>>>>>> MPID_nem_mpich2_blocking_recv(933):
>>>>>>>>>>>> MPID_nem_tcp_connpoll(1709).......: Communication error
>>>>>>>>>>>> Fatal
>>>>>>>>>>>> error
>>>>>>>>>>>> in
>>>>>>>>>>> new_comm=0x7fff
>>>>>>>>>>> 97dca620) failed
>>>>>>>>>>> rbuf=0x7fff
>>>>>>>>>>> 97dca370, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>>>>>>>>> MPIR_Allreduce(289)...............:
>>>>>>>>>>>> MPIC_Sendrecv(161)................:
>>>>>>>>>>>> MPID_nem_mpich2_blocking_recv(948):
>>>>>>>>>>>> Killed
>>>>>> by
>>>>>>>>>>>> signal 2.
>>>>>>>>>>>> Ctrl-C caught... cleaning up processes [mpiexec at athos]
>>>>>>>>>>>> HYDT_dmx_deregister_fd (./tools/demux/demux.c:142): could
>>>>>>>>>>>> not
>>>>>>>>>>>> find
>>>>>>>>>>>> fd
>>>>>>>>>>>> to deregister: -2 [mpiexec at athos] HYD_pmcd_pmiserv_cleanup
>>>>>>>>>>>> (./pm/pmiserv/pmiserv_cb.c:401): error deregistering fd
>>>>>>>>>>>> [press
>>>>>>>>>>>> Ctrl-C
>>>>>>>>>>>> again to force abort] APPLICATION TERMINATED WITH THE EXIT
>>>>>> STRING:
>>>>>>>>>>>> Killed (signal 9) [mcnp5_1-4 at athos ~]$ Any ideas?
>>>>>>>>>>>> Thanks in advance,
>>>>>>>>>>>> David Sullivan
>>>>>>>>>>>> AREVA NP INC
>>>>>>>>>>>> 400 Donald Lynch Boulevard
>>>>>>>>>>>> Marlborough, MA, 01752
>>>>>>>>>>>> Phone: (508) 573-6721
>>>>>>>>>>>> Fax: (434) 382-5597
>>>>>>>>>>>> David.Sullivan at AREVA.com
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> mpich-discuss mailing list
>>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>>>>>> <summary.xml>_______________________________________________
>>>>> <summary.xml><error.txt>___________________________________________
>>>>> _
>>>>> ___
>>>> <winmail.dat>_______________________________________________
> <testing_screen.txt>_______________________________________________
