[mpich-discuss] cryptic (to me) error
    SULLIVAN David (AREVA)
    David.Sullivan at areva.com
    Thu Sep  2 18:27:48 CDT 2010
The error occurs immediately- I don't think it even starts the executable. It does work on the single machine with 4 processes.
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov on behalf of Rajeev Thakur
Sent: Thu 9/2/2010 4:34 PM
Subject: Re: [mpich-discuss] cryptic (to me) error
Does it run with 2 processes on a single machine?
On Sep 2, 2010, at 2:38 PM, SULLIVAN David (AREVA) wrote:
> That fixed the compile. Thanks!
> The latest release does not fix the issues I am having though. Cpi works
> fine, the test suit is certainly improved (see summary.xml output)
> though when I try to use mcnp it still crashes in the same way (see
> error.txt)
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Anthony Chan
> Sent: Thursday, September 02, 2010 1:38 PM
> There is a bug in 1.3b1 about the option --enable-fc.  Since Fortran 90
> is enabled by default, so remove the --enable-fc from your configure
> command and try again.  If there is error again, send us the configure
> output as you seen on your screen (See README) instead of config.log.
> A.Chan
> ----- "SULLIVAN David (AREVA)" <David.Sullivan at areva.com> wrote:
>> Failure again.
>> The 1.3 beta version will not compile with Intel 10.1. It bombs at the
>> configuration script:
>> checking for Fortran flag needed to allow free-form source... unknown
>> configure: WARNING: Fortran 90 test being disabled because the
>> /home/dfs/mpich2-1.3b1/bin/mpif90 compiler does not accept a .f90
>> extension
>> configure: error: Fortran does not accept free-form source
>> configure: error: ./configure failed for test/mpi
>> I have attached to config.log
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
>> Sent: Thursday, September 02, 2010 12:11 PM
>> Just try relinking with the new library at first.
>> Rajeev
>> On Sep 2, 2010, at 9:32 AM, SULLIVAN David (AREVA) wrote:
>>> I saw that there was a newer beta. I was really hoping to find I
>> just
>>> configured something incorrectly. Will this not require me to
>> re-build
>>> mcnp (the only program I run that uses mpi for parallel) if I change
>>> the mpi version? If so, this is a bit of a hardship, requiring codes
>>> to be revalidated. If not- I will try it in a second.
>>> Thanks,
>>> Dave
>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave
>> Goodell
>>> Sent: Thursday, September 02, 2010 10:27 AM
>>> Can you try the latest release (1.3b1) to see if that fixes the
>>> problems you are seeing with your application?
>> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=
>>> do
>>> wnloads
>>> -Dave
>>> On Sep 2, 2010, at 9:15 AM CDT, SULLIVAN David (AREVA) wrote:
>>>> Another output file, hopefully of use.
>>>> Thanks again
>>>> Dave
>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of SULLIVAN
>>>> David
>>>> (AREVA)
>>>> Sent: Thursday, September 02, 2010 8:20 AM
>>>> First my apologies for the delay in continuing this thread.
>>>> Unfortunately I have not resolved it so if I can indulge the gurus
>>>> and
>>>> developers once again...
>>>> As suggested by Rajeev I ran the testing suit in the source
>> directory.
>>>> The output of errors, which are similar to what I was seeing when I
>>>> ran
>>>> mcnp5 (v. 1.40 and 1.51), is attached.
>>>> Any insights would be greatly appreciated,
>>>> Dave
>> Thakur
>>>> Sent: Wednesday, August 04, 2010 3:06 PM
>>>> Then one level above that directory (in the main MPICH2 source
>>>> directory), type make testing, which will run through the entire
>>>> MPICH2 test suite.
>>>> Rajeev
>>>> On Aug 4, 2010, at 2:04 PM, SULLIVAN David (AREVA) wrote:
>>>>> Oh. That's  embarrassing. Yea. I have those examples. It runs
>> with
>>>>> no
>>>>> problems:
>>>>> [dfs at aramis examples]$ mpiexec -host aramis -n 4 ./cpi Process 2
>> of
>>>>> 4
>>>>> is on aramis Process 3 of 4 is on aramis Process 0 of 4 is on
>> aramis
>>>>> Process 1 of 4 is on aramis pi is approximately
>> 3.1415926544231239,
>>>>> Error is 0.0000000008333307 wall clock time = 0.000652
>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus
>> Correa
>>>>> Sent: Wednesday, August 04, 2010 1:13 PM
>>>>> To: Mpich Discuss
>>>>> Hi David
>>>>> I think the "examples" dir is not copied to the installation
>>>> directory.
>>>>> You may find it where you decompressed the MPICH2 tarball, in case
>>>>> you
>>>>> installed it from source.
>>>>> At least, this is what I have here.
>>>>> Gus Correa
>>>>>> Yea, that always bothered me.  There is no such folder.
>>>>>> There are :
>>>>>> bin
>>>>>> etc
>>>>>> include
>>>>>> lib
>>>>>> sbin
>>>>>> share
>>>>>> The  only examples I found were in the  share folder,  where
>> there
>>>>> are
>>>>>> examples for collchk,  graphics and  logging.
>>>>>> Thakur
>>>>>> Sent: Wednesday, August 04, 2010 12:45 PM
>>>>>> Not cpilog. Can you run just cpi from the mpich2/examples
>> directory.
>>>>>> Rajeev
>>>>>> On Aug 4, 2010, at 11:37 AM, SULLIVAN David (AREVA) wrote:
>>>>>>> Rajeev,  Darius,
>>>>>>> Thanks for your response.
>>>>>>> cpi yields  the  following-
>>>>>>> [dfs at aramis examples_logging]$ mpiexec -host aramis -n 12
>> ./cpilog
>>>>>>> Process 0 running on aramis Process 2 running on aramis Process
>> 3
>>>>>>> running on aramis Process 1 running on aramis Process 6 running
>> on
>>>>>>> aramis Process 7 running on aramis Process 8 running on aramis
>>>>>>> Process
>>>>>>> 4 running on aramis Process 5 running on aramis Process 9
>> running
>>>>>>> on
>>>>>>> aramis Process 10 running on aramis Process 11 running on aramis
>>>>>>> pi
>>>>>>> is
>>>>>>> approximately 3.1415926535898762, Error is 0.0000000000000830
>> wall
>>>>>>> clock time = 0.058131 Writing logfile....
>>>>>>> Enabling the Default clock synchronization...
>>>>>>> clog_merger.c:CLOG_Merger_init() -
>>>>>>>    Could not open file ./cpilog.clog2 for merging!
>>>>>>> Backtrace of the callstack at rank 0:
>>>>>>>    At [0]: ./cpilog(CLOG_Util_abort+0x92)[0x456326]
>>>>>>>    At [1]: ./cpilog(CLOG_Merger_init+0x11f)[0x45db7c]
>>>>>>>    At [2]: ./cpilog(CLOG_Converge_init+0x8e)[0x45a691]
>>>>>>>    At [3]: ./cpilog(MPE_Finish_log+0xea)[0x4560aa]
>>>>>>>    At [4]: ./cpilog(MPI_Finalize+0x50c)[0x4268af]
>>>>>>>    At [5]: ./cpilog(main+0x428)[0x415963]
>>>>>>>    At [6]:
>> /lib64/libc.so.6(__libc_start_main+0xf4)[0x3c1881d994]
>>>>>>>    At [7]: ./cpilog[0x415449]
>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>>>>> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal
>>>>>>> 15)
>>>>>>> So  it looks like it works  with some issues.
>>>>>>> When does  it fail? Immediately
>>>>>>> Is there  a  bug? Many sucessfully use the aplication (MCNP5,
>>>>>>> from
>>>>>>> LANL) with  mpi,  so  think that  a  bug there is  unlikely.
>>>>>>> Core files, unfortunately reveals some ignorance on my part.
>> Were
>>>>>>> exactly should I be looking for them?
>>>>>>> Thanks again,
>>>>>>> Dave
>>>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius
>>>>>>> Buntinas
>>>>>>> Sent: Wednesday, August 04, 2010 12:19 PM
>>>>>>> This error message says that two processes terminated because
>> they
>>>>>>> were unable to communicate with another (or two other) process.
>>>> It's
>>>>>>> possible that another process died, so the others got errors
>>>>>>> trying
>>>>>>> to
>>>>>>> communicate with them.  It's also possible that there is
>> something
>>>>>>> preventing some processes from communicating with each other.
>>>>>>> Are you able to run cpi from the examples directory with 12
>>>>> processes?
>>>>>>> At what point in your code does this fail?  Are there any other
>>>>>>> communication operations before the MPI_Comm_dup?
>>>>>>> Enable core files (add "ulimit -c unlimited" to your .bashrc or
>>>>>>> .tcshrc) then run your app and look for core files.  If there is
>> a
>>>>>>> bug
>>>>>>> in your application that causes a process to die this might tell
>>>>>>> you
>>>>>>> which one and why.
>>>>>>> Let us know how this goes.
>>>>>>> -d
>>>>>>> On Aug 4, 2010, at 11:03 AM, SULLIVAN David (AREVA) wrote:
>>>>>>>> Since I have  had  no responses, is  there any other
>> additional
>>>>>>> information could I provide to solicit some direction for
>>>>>>> overcoming
>>>>>>> these latest string of mpi errors?
>>>>>>>> Thanks,
>>>>>>>> Dave
>> SULLIVAN
>>>>>>>> David F (AREVA NP INC)
>>>>>>>> Sent: Friday, July 23, 2010 4:29 PM
>>>>>>>> Subject: [mpich-discuss] cryptic (to me) error
>>>>>>>> With my firewall issues firmly behind me, I have a new problem
>>>>>>>> for
>>>>>>>> the
>>>>>>> collective wisdom. I am attempting to run a program to which the
>>>>>>> response is as follows:
>>>>>>>> [mcnp5_1-4 at athos ~]$ mpiexec -f nodes -n 12 mcnp5.mpi i=TN04
>>>>>>>> o=TN04.o
>>>>>>>> Fatal error in MPI_Comm_dup: Other MPI error, error stack:
>>>>>>>> MPI_Comm_dup(168).................:
>> MPI_Comm_dup(MPI_COMM_WORLD,
>>>>>>>> new_comm=0x7fff58edb450) failed
>>>>>>>> MPIR_Comm_copy(923)...............:
>>>>>>>> MPIR_Get_contextid(639)...........:
>>>>>>>> MPI_Allreduce(773)................:
>>>> MPI_Allreduce(sbuf=MPI_IN_PLACE,
>>>>>>> rbuf=0x7fff
>>>>>>> 58edb1a0, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>>>>> MPIR_Allreduce(228)...............:
>>>>>>>> MPIC_Send(41).....................:
>>>>>>>> MPIC_Wait(513)....................:
>>>>>>>> MPIDI_CH3I_Progress(150)..........:
>>>>>>>> MPID_nem_mpich2_blocking_recv(933):
>>>>>>>> MPID_nem_tcp_connpoll(1709).......: Communication error Fatal
>>>>>>>> error
>>>>>>>> in
>>>>>>> new_comm=0x7fff
>>>>>>> 97dca620) failed
>>>>>>> rbuf=0x7fff
>>>>>>> 97dca370, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>>>>> MPIR_Allreduce(289)...............:
>>>>>>>> MPIC_Sendrecv(161)................:
>>>>>>>> MPID_nem_mpich2_blocking_recv(948):
>>>>>>>> MPID_nem_tcp_connpoll(1709).......: Communication error Killed
>> by
>>>>>>>> signal 2.
>>>>>>>> Ctrl-C caught... cleaning up processes [mpiexec at athos]
>>>>>>>> HYDT_dmx_deregister_fd (./tools/demux/demux.c:142): could not
>>>>>>>> find
>>>>>>>> fd
>>>>>>>> to deregister: -2 [mpiexec at athos] HYD_pmcd_pmiserv_cleanup
>>>>>>>> (./pm/pmiserv/pmiserv_cb.c:401): error deregistering fd [press
>>>>>>>> Ctrl-C
>>>>>>>> again to force abort] APPLICATION TERMINATED WITH THE EXIT
>> STRING:
>>>>>>>> Killed (signal 9) [mcnp5_1-4 at athos ~]$ Any ideas?
>>>>>>>> Thanks in advance,
>>>>>>>> David Sullivan
>>>>>>>> AREVA NP INC
>>>>>>>> 400 Donald Lynch Boulevard
>>>>>>>> Marlborough, MA, 01752
>>>>>>>> Phone: (508) 573-6721
>>>>>>>> Fax: (434) 382-5597
>>>>>>>> David.Sullivan at AREVA.com
>>>>>>>> _______________________________________________
>>>>>>>> mpich-discuss mailing list
>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>> <summary.xml>_______________________________________________
> <summary.xml><error.txt>_______________________________________________
Name: not available
Type: application/ms-tnef
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100902/c3362059/attachment.bin>
