[mpich-discuss] cryptic (to me) error
    SULLIVAN David (AREVA)
    David.Sullivan at areva.com
    Thu Sep  2 12:24:53 CDT 2010
Failure again.
The 1.3 beta version will not compile with Intel 10.1. It bombs at the
configuration script:
checking for Fortran flag needed to allow free-form source... unknown
configure: WARNING: Fortran 90 test being disabled because the
/home/dfs/mpich2-1.3b1/bin/mpif90 compiler does not accept a .f90
extension
configure: error: Fortran does not accept free-form source
configure: error: ./configure failed for test/mpi
I have attached to config.log
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
Sent: Thursday, September 02, 2010 12:11 PM
Subject: Re: [mpich-discuss] cryptic (to me) error
Just try relinking with the new library at first.
Rajeev
On Sep 2, 2010, at 9:32 AM, SULLIVAN David (AREVA) wrote:
> I saw that there was a newer beta. I was really hoping to find I just
> configured something incorrectly. Will this not require me to re-build
> mcnp (the only program I run that uses mpi for parallel) if I change
> the mpi version? If so, this is a bit of a hardship, requiring codes
> to be revalidated. If not- I will try it in a second.
> Thanks,
> Dave
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
> Sent: Thursday, September 02, 2010 10:27 AM
> Can you try the latest release (1.3b1) to see if that fixes the
> problems you are seeing with your application?
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=
> do
> wnloads
> -Dave
> On Sep 2, 2010, at 9:15 AM CDT, SULLIVAN David (AREVA) wrote:
>> Another output file, hopefully of use.
>> Thanks again
>> Dave
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of SULLIVAN
>> David
>> (AREVA)
>> Sent: Thursday, September 02, 2010 8:20 AM
>> First my apologies for the delay in continuing this thread.
>> Unfortunately I have not resolved it so if I can indulge the gurus
>> and
>> developers once again...
>> As suggested by Rajeev I ran the testing suit in the source
directory.
>> The output of errors, which are similar to what I was seeing when I
>> ran
>> mcnp5 (v. 1.40 and 1.51), is attached.
>> Any insights would be greatly appreciated,
>> Dave
>> Sent: Wednesday, August 04, 2010 3:06 PM
>> Then one level above that directory (in the main MPICH2 source
>> directory), type make testing, which will run through the entire
>> MPICH2 test suite.
>> Rajeev
>> On Aug 4, 2010, at 2:04 PM, SULLIVAN David (AREVA) wrote:
>>> Oh. That's  embarrassing. Yea. I have those examples. It runs  with
>>> no
>>> problems:
>>> [dfs at aramis examples]$ mpiexec -host aramis -n 4 ./cpi Process 2 of
>>> 4
>>> is on aramis Process 3 of 4 is on aramis Process 0 of 4 is on aramis
>>> Process 1 of 4 is on aramis pi is approximately 3.1415926544231239,
>>> Error is 0.0000000008333307 wall clock time = 0.000652
>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus Correa
>>> Sent: Wednesday, August 04, 2010 1:13 PM
>>> To: Mpich Discuss
>>> Hi David
>>> I think the "examples" dir is not copied to the installation
>> directory.
>>> You may find it where you decompressed the MPICH2 tarball, in case
>>> you
>>> installed it from source.
>>> At least, this is what I have here.
>>> Gus Correa
>>>> Yea, that always bothered me.  There is no such folder.
>>>> There are :
>>>> bin
>>>> etc
>>>> include
>>>> lib
>>>> sbin
>>>> share
>>>> The  only examples I found were in the  share folder,  where  there
>>> are
>>>> examples for collchk,  graphics and  logging.
>>>> Thakur
>>>> Sent: Wednesday, August 04, 2010 12:45 PM
>>>> Not cpilog. Can you run just cpi from the mpich2/examples
directory.
>>>> Rajeev
>>>> On Aug 4, 2010, at 11:37 AM, SULLIVAN David (AREVA) wrote:
>>>>> Rajeev,  Darius,
>>>>> Thanks for your response.
>>>>> cpi yields  the  following-
>>>>> [dfs at aramis examples_logging]$ mpiexec -host aramis -n 12 ./cpilog
>>>>> Process 0 running on aramis Process 2 running on aramis Process 3
>>>>> running on aramis Process 1 running on aramis Process 6 running on
>>>>> aramis Process 7 running on aramis Process 8 running on aramis
>>>>> Process
>>>>> 4 running on aramis Process 5 running on aramis Process 9 running
>>>>> on
>>>>> aramis Process 10 running on aramis Process 11 running on aramis
>>>>> pi
>>>>> is
>>>>> approximately 3.1415926535898762, Error is 0.0000000000000830 wall
>>>>> clock time = 0.058131 Writing logfile....
>>>>> Enabling the Default clock synchronization...
>>>>> clog_merger.c:CLOG_Merger_init() -
>>>>>     Could not open file ./cpilog.clog2 for merging!
>>>>> Backtrace of the callstack at rank 0:
>>>>>     At [0]: ./cpilog(CLOG_Util_abort+0x92)[0x456326]
>>>>>     At [1]: ./cpilog(CLOG_Merger_init+0x11f)[0x45db7c]
>>>>>     At [2]: ./cpilog(CLOG_Converge_init+0x8e)[0x45a691]
>>>>>     At [3]: ./cpilog(MPE_Finish_log+0xea)[0x4560aa]
>>>>>     At [4]: ./cpilog(MPI_Finalize+0x50c)[0x4268af]
>>>>>     At [5]: ./cpilog(main+0x428)[0x415963]
>>>>>     At [6]: /lib64/libc.so.6(__libc_start_main+0xf4)[0x3c1881d994]
>>>>>     At [7]: ./cpilog[0x415449]
>>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>>> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal
>>>>> 15)
>>>>> So  it looks like it works  with some issues.
>>>>> When does  it fail? Immediately
>>>>> Is there  a  bug? Many sucessfully use the aplication (MCNP5,
>>>>> from
>>>>> LANL) with  mpi,  so  think that  a  bug there is  unlikely.
>>>>> Core files, unfortunately reveals some ignorance on my part. Were
>>>>> exactly should I be looking for them?
>>>>> Thanks again,
>>>>> Dave
>>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius
>>>>> Buntinas
>>>>> Sent: Wednesday, August 04, 2010 12:19 PM
>>>>> This error message says that two processes terminated because they
>>>>> were unable to communicate with another (or two other) process.
>> It's
>>>>> possible that another process died, so the others got errors
>>>>> trying
>>>>> to
>>>>> communicate with them.  It's also possible that there is something
>>>>> preventing some processes from communicating with each other.
>>>>> Are you able to run cpi from the examples directory with 12
>>> processes?
>>>>> At what point in your code does this fail?  Are there any other
>>>>> communication operations before the MPI_Comm_dup?
>>>>> Enable core files (add "ulimit -c unlimited" to your .bashrc or
>>>>> .tcshrc) then run your app and look for core files.  If there is a
>>>>> bug
>>>>> in your application that causes a process to die this might tell
>>>>> you
>>>>> which one and why.
>>>>> Let us know how this goes.
>>>>> -d
>>>>> On Aug 4, 2010, at 11:03 AM, SULLIVAN David (AREVA) wrote:
>>>>>> Since I have  had  no responses, is  there any other additional
>>>>> information could I provide to solicit some direction for
>>>>> overcoming
>>>>> these latest string of mpi errors?
>>>>>> Thanks,
>>>>>> Dave
>>>>>> David F (AREVA NP INC)
>>>>>> Sent: Friday, July 23, 2010 4:29 PM
>>>>>> Subject: [mpich-discuss] cryptic (to me) error
>>>>>> With my firewall issues firmly behind me, I have a new problem
>>>>>> for
>>>>>> the
>>>>> collective wisdom. I am attempting to run a program to which the
>>>>> response is as follows:
>>>>>> [mcnp5_1-4 at athos ~]$ mpiexec -f nodes -n 12 mcnp5.mpi i=TN04
>>>>>> o=TN04.o
>>>>>> Fatal error in MPI_Comm_dup: Other MPI error, error stack:
>>>>>> MPI_Comm_dup(168).................: MPI_Comm_dup(MPI_COMM_WORLD,
>>>>>> new_comm=0x7fff58edb450) failed
>>>>>> MPIR_Comm_copy(923)...............:
>>>>>> MPIR_Get_contextid(639)...........:
>>>>>> MPI_Allreduce(773)................:
>> MPI_Allreduce(sbuf=MPI_IN_PLACE,
>>>>> rbuf=0x7fff
>>>>> 58edb1a0, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>>> MPIR_Allreduce(228)...............:
>>>>>> MPIC_Send(41).....................:
>>>>>> MPIC_Wait(513)....................:
>>>>>> MPIDI_CH3I_Progress(150)..........:
>>>>>> MPID_nem_mpich2_blocking_recv(933):
>>>>>> MPID_nem_tcp_connpoll(1709).......: Communication error Fatal
>>>>>> error
>>>>>> in
>>>>> new_comm=0x7fff
>>>>> 97dca620) failed
>>>>> rbuf=0x7fff
>>>>> 97dca370, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>>> MPIR_Allreduce(289)...............:
>>>>>> MPIC_Sendrecv(161)................:
>>>>>> MPID_nem_mpich2_blocking_recv(948):
>>>>>> MPID_nem_tcp_connpoll(1709).......: Communication error Killed by
>>>>>> signal 2.
>>>>>> Ctrl-C caught... cleaning up processes [mpiexec at athos]
>>>>>> HYDT_dmx_deregister_fd (./tools/demux/demux.c:142): could not
>>>>>> find
>>>>>> fd
>>>>>> to deregister: -2 [mpiexec at athos] HYD_pmcd_pmiserv_cleanup
>>>>>> (./pm/pmiserv/pmiserv_cb.c:401): error deregistering fd [press
>>>>>> Ctrl-C
>>>>>> again to force abort] APPLICATION TERMINATED WITH THE EXIT
STRING:
>>>>>> Killed (signal 9) [mcnp5_1-4 at athos ~]$ Any ideas?
>>>>>> Thanks in advance,
>>>>>> David Sullivan
>>>>>> AREVA NP INC
>>>>>> 400 Donald Lynch Boulevard
>>>>>> Marlborough, MA, 01752
>>>>>> Phone: (508) 573-6721
>>>>>> Fax: (434) 382-5597
>>>>>> David.Sullivan at AREVA.com
>>>>>> _______________________________________________
>>>>>> mpich-discuss mailing list
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> <summary.xml>_______________________________________________
Desc: config.log
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100902/bc3f7235/attachment-0001.obj>
