[mpich-discuss] cryptic (to me) error
    SULLIVAN David (AREVA)
    David.Sullivan at areva.com
    Thu Sep  2 09:32:21 CDT 2010
I saw that there was a newer beta. I was really hoping to find I just
configured something incorrectly. Will this not require me to re-build
mcnp (the only program I run that uses mpi for parallel) if I change the
mpi version? If so, this is a bit of a hardship, requiring codes to be
revalidated. If not- I will try it in a second.
Dave
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
Sent: Thursday, September 02, 2010 10:27 AM
Subject: Re: [mpich-discuss] cryptic (to me) error
Can you try the latest release (1.3b1) to see if that fixes the problems
you are seeing with your application?
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=do
wnloads
-Dave
On Sep 2, 2010, at 9:15 AM CDT, SULLIVAN David (AREVA) wrote:
> Another output file, hopefully of use.
> Thanks again
> Dave
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of SULLIVAN David
> (AREVA)
> Sent: Thursday, September 02, 2010 8:20 AM
> First my apologies for the delay in continuing this thread.
> Unfortunately I have not resolved it so if I can indulge the gurus and
> developers once again...
> As suggested by Rajeev I ran the testing suit in the source directory.
> The output of errors, which are similar to what I was seeing when I
> ran
> mcnp5 (v. 1.40 and 1.51), is attached.
> Any insights would be greatly appreciated,
> Dave
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
> Sent: Wednesday, August 04, 2010 3:06 PM
> Then one level above that directory (in the main MPICH2 source
> directory), type make testing, which will run through the entire
> MPICH2 test suite.
> Rajeev
> On Aug 4, 2010, at 2:04 PM, SULLIVAN David (AREVA) wrote:
>> Oh. That's  embarrassing. Yea. I have those examples. It runs  with
>> no
>> problems:
>> [dfs at aramis examples]$ mpiexec -host aramis -n 4 ./cpi Process 2 of 4
>> is on aramis Process 3 of 4 is on aramis Process 0 of 4 is on aramis
>> Process 1 of 4 is on aramis pi is approximately 3.1415926544231239,
>> Error is 0.0000000008333307 wall clock time = 0.000652
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus Correa
>> Sent: Wednesday, August 04, 2010 1:13 PM
>> To: Mpich Discuss
>> Hi David
>> I think the "examples" dir is not copied to the installation
> directory.
>> You may find it where you decompressed the MPICH2 tarball, in case
>> you
>> installed it from source.
>> At least, this is what I have here.
>> Gus Correa
>>> Yea, that always bothered me.  There is no such folder.
>>> There are :
>>> bin
>>> etc
>>> include
>>> lib
>>> sbin
>>> share
>>> The  only examples I found were in the  share folder,  where  there
>> are
>>> examples for collchk,  graphics and  logging.
>>> Thakur
>>> Sent: Wednesday, August 04, 2010 12:45 PM
>>> Not cpilog. Can you run just cpi from the mpich2/examples directory.
>>> Rajeev
>>> On Aug 4, 2010, at 11:37 AM, SULLIVAN David (AREVA) wrote:
>>>> Rajeev,  Darius,
>>>> Thanks for your response.
>>>> cpi yields  the  following-
>>>> [dfs at aramis examples_logging]$ mpiexec -host aramis -n 12 ./cpilog
>>>> Process 0 running on aramis Process 2 running on aramis Process 3
>>>> running on aramis Process 1 running on aramis Process 6 running on
>>>> aramis Process 7 running on aramis Process 8 running on aramis
>>>> Process
>>>> 4 running on aramis Process 5 running on aramis Process 9 running
>>>> on
>>>> aramis Process 10 running on aramis Process 11 running on aramis pi
>>>> is
>>>> approximately 3.1415926535898762, Error is 0.0000000000000830 wall
>>>> clock time = 0.058131 Writing logfile....
>>>> Enabling the Default clock synchronization...
>>>> clog_merger.c:CLOG_Merger_init() -
>>>>      Could not open file ./cpilog.clog2 for merging!
>>>> Backtrace of the callstack at rank 0:
>>>>      At [0]: ./cpilog(CLOG_Util_abort+0x92)[0x456326]
>>>>      At [1]: ./cpilog(CLOG_Merger_init+0x11f)[0x45db7c]
>>>>      At [2]: ./cpilog(CLOG_Converge_init+0x8e)[0x45a691]
>>>>      At [3]: ./cpilog(MPE_Finish_log+0xea)[0x4560aa]
>>>>      At [4]: ./cpilog(MPI_Finalize+0x50c)[0x4268af]
>>>>      At [5]: ./cpilog(main+0x428)[0x415963]
>>>>      At [6]: /lib64/libc.so.6(__libc_start_main+0xf4)[0x3c1881d994]
>>>>      At [7]: ./cpilog[0x415449]
>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
>>>> So  it looks like it works  with some issues.
>>>> When does  it fail? Immediately
>>>> Is there  a  bug? Many sucessfully use the aplication (MCNP5,  from
>>>> LANL) with  mpi,  so  think that  a  bug there is  unlikely.
>>>> Core files, unfortunately reveals some ignorance on my part. Were
>>>> exactly should I be looking for them?
>>>> Thanks again,
>>>> Dave
>>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius
>>>> Buntinas
>>>> Sent: Wednesday, August 04, 2010 12:19 PM
>>>> This error message says that two processes terminated because they
>>>> were unable to communicate with another (or two other) process.
> It's
>>>> possible that another process died, so the others got errors trying
>>>> to
>>>> communicate with them.  It's also possible that there is something
>>>> preventing some processes from communicating with each other.
>>>> Are you able to run cpi from the examples directory with 12
>> processes?
>>>> At what point in your code does this fail?  Are there any other
>>>> communication operations before the MPI_Comm_dup?
>>>> Enable core files (add "ulimit -c unlimited" to your .bashrc or
>>>> .tcshrc) then run your app and look for core files.  If there is a
>>>> bug
>>>> in your application that causes a process to die this might tell
>>>> you
>>>> which one and why.
>>>> Let us know how this goes.
>>>> -d
>>>> On Aug 4, 2010, at 11:03 AM, SULLIVAN David (AREVA) wrote:
>>>>> Since I have  had  no responses, is  there any other additional
>>>> information could I provide to solicit some direction for
>>>> overcoming
>>>> these latest string of mpi errors?
>>>>> Thanks,
>>>>> Dave
>>>>> David F (AREVA NP INC)
>>>>> Sent: Friday, July 23, 2010 4:29 PM
>>>>> Subject: [mpich-discuss] cryptic (to me) error
>>>>> With my firewall issues firmly behind me, I have a new problem for
>>>>> the
>>>> collective wisdom. I am attempting to run a program to which the
>>>> response is as follows:
>>>>> [mcnp5_1-4 at athos ~]$ mpiexec -f nodes -n 12 mcnp5.mpi i=TN04
>>>>> o=TN04.o
>>>>> Fatal error in MPI_Comm_dup: Other MPI error, error stack:
>>>>> MPI_Comm_dup(168).................: MPI_Comm_dup(MPI_COMM_WORLD,
>>>>> new_comm=0x7fff58edb450) failed
>>>>> MPIR_Comm_copy(923)...............:
>>>>> MPIR_Get_contextid(639)...........:
>>>>> MPI_Allreduce(773)................:
> MPI_Allreduce(sbuf=MPI_IN_PLACE,
>>>> rbuf=0x7fff
>>>> 58edb1a0, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>> MPIR_Allreduce(228)...............:
>>>>> MPIC_Send(41).....................:
>>>>> MPIC_Wait(513)....................:
>>>>> MPIDI_CH3I_Progress(150)..........:
>>>>> MPID_nem_mpich2_blocking_recv(933):
>>>>> MPID_nem_tcp_connpoll(1709).......: Communication error Fatal
>>>>> error
>>>>> in
>>>> new_comm=0x7fff
>>>> 97dca620) failed
>>>> rbuf=0x7fff
>>>> 97dca370, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>>> MPIR_Allreduce(289)...............:
>>>>> MPIC_Sendrecv(161)................:
>>>>> MPID_nem_mpich2_blocking_recv(948):
>>>>> MPID_nem_tcp_connpoll(1709).......: Communication error Killed by
>>>>> signal 2.
>>>>> Ctrl-C caught... cleaning up processes [mpiexec at athos]
>>>>> HYDT_dmx_deregister_fd (./tools/demux/demux.c:142): could not find
>>>>> fd
>>>>> to deregister: -2 [mpiexec at athos] HYD_pmcd_pmiserv_cleanup
>>>>> (./pm/pmiserv/pmiserv_cb.c:401): error deregistering fd [press
>>>>> Ctrl-C
>>>>> again to force abort] APPLICATION TERMINATED WITH THE EXIT STRING:
>>>>> Killed (signal 9) [mcnp5_1-4 at athos ~]$ Any ideas?
>>>>> Thanks in advance,
>>>>> David Sullivan
>>>>> AREVA NP INC
>>>>> 400 Donald Lynch Boulevard
>>>>> Marlborough, MA, 01752
>>>>> Phone: (508) 573-6721
>>>>> Fax: (434) 382-5597
>>>>> David.Sullivan at AREVA.com
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> <summary.xml>_______________________________________________
