[mpich-discuss] cryptic (to me) error
    SULLIVAN David (AREVA)
    David.Sullivan at areva.com
    Thu Sep  2 09:15:46 CDT 2010
Another output file, hopefully of use.
Thanks again
Dave
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of SULLIVAN David
(AREVA)
Sent: Thursday, September 02, 2010 8:20 AM
Subject: Re: [mpich-discuss] cryptic (to me) error
First my apologies for the delay in continuing this thread.
Unfortunately I have not resolved it so if I can indulge the gurus and
developers once again...
As suggested by Rajeev I ran the testing suit in the source directory.
The output of errors, which are similar to what I was seeing when I ran
mcnp5 (v. 1.40 and 1.51), is attached.
Any insights would be greatly appreciated,
Dave
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
Sent: Wednesday, August 04, 2010 3:06 PM
Then one level above that directory (in the main MPICH2 source
directory), type make testing, which will run through the entire MPICH2
test suite.
Rajeev
On Aug 4, 2010, at 2:04 PM, SULLIVAN David (AREVA) wrote:
> Oh. That's  embarrassing. Yea. I have those examples. It runs  with no
> problems:
> [dfs at aramis examples]$ mpiexec -host aramis -n 4 ./cpi Process 2 of 4
> is on aramis Process 3 of 4 is on aramis Process 0 of 4 is on aramis
> Process 1 of 4 is on aramis pi is approximately 3.1415926544231239,
> Error is 0.0000000008333307 wall clock time = 0.000652
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus Correa
> Sent: Wednesday, August 04, 2010 1:13 PM
> To: Mpich Discuss
> Hi David
> I think the "examples" dir is not copied to the installation
directory.
> You may find it where you decompressed the MPICH2 tarball, in case you
> installed it from source.
> At least, this is what I have here.
> Gus Correa
>> Yea, that always bothered me.  There is no such folder.
>> There are :
>> bin
>> etc
>> include
>> lib
>> sbin
>> share
>> The  only examples I found were in the  share folder,  where  there
> are
>> examples for collchk,  graphics and  logging.
>> Sent: Wednesday, August 04, 2010 12:45 PM
>> Not cpilog. Can you run just cpi from the mpich2/examples directory.
>> Rajeev
>> On Aug 4, 2010, at 11:37 AM, SULLIVAN David (AREVA) wrote:
>>> Rajeev,  Darius,
>>> Thanks for your response.
>>> cpi yields  the  following-
>>> [dfs at aramis examples_logging]$ mpiexec -host aramis -n 12 ./cpilog
>>> Process 0 running on aramis Process 2 running on aramis Process 3
>>> running on aramis Process 1 running on aramis Process 6 running on
>>> aramis Process 7 running on aramis Process 8 running on aramis
>>> Process
>>> 4 running on aramis Process 5 running on aramis Process 9 running on
>>> aramis Process 10 running on aramis Process 11 running on aramis pi
>>> is
>>> approximately 3.1415926535898762, Error is 0.0000000000000830 wall
>>> clock time = 0.058131 Writing logfile....
>>> Enabling the Default clock synchronization...
>>> clog_merger.c:CLOG_Merger_init() -
>>>       Could not open file ./cpilog.clog2 for merging!
>>> Backtrace of the callstack at rank 0:
>>>       At [0]: ./cpilog(CLOG_Util_abort+0x92)[0x456326]
>>>       At [1]: ./cpilog(CLOG_Merger_init+0x11f)[0x45db7c]
>>>       At [2]: ./cpilog(CLOG_Converge_init+0x8e)[0x45a691]
>>>       At [3]: ./cpilog(MPE_Finish_log+0xea)[0x4560aa]
>>>       At [4]: ./cpilog(MPI_Finalize+0x50c)[0x4268af]
>>>       At [5]: ./cpilog(main+0x428)[0x415963]
>>>       At [6]: /lib64/libc.so.6(__libc_start_main+0xf4)[0x3c1881d994]
>>>       At [7]: ./cpilog[0x415449]
>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
>>> So  it looks like it works  with some issues.
>>> When does  it fail? Immediately
>>> Is there  a  bug? Many sucessfully use the aplication (MCNP5,  from
>>> LANL) with  mpi,  so  think that  a  bug there is  unlikely.
>>> Core files, unfortunately reveals some ignorance on my part. Were
>>> exactly should I be looking for them?
>>> Thanks again,
>>> Dave
>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Darius
>>> Buntinas
>>> Sent: Wednesday, August 04, 2010 12:19 PM
>>> This error message says that two processes terminated because they
>>> were unable to communicate with another (or two other) process.
It's
>>> possible that another process died, so the others got errors trying
>>> to
>>> communicate with them.  It's also possible that there is something
>>> preventing some processes from communicating with each other.
>>> Are you able to run cpi from the examples directory with 12
> processes?
>>> At what point in your code does this fail?  Are there any other
>>> communication operations before the MPI_Comm_dup?
>>> Enable core files (add "ulimit -c unlimited" to your .bashrc or
>>> .tcshrc) then run your app and look for core files.  If there is a
>>> bug
>>> in your application that causes a process to die this might tell you
>>> which one and why.
>>> Let us know how this goes.
>>> -d
>>> On Aug 4, 2010, at 11:03 AM, SULLIVAN David (AREVA) wrote:
>>>> Since I have  had  no responses, is  there any other additional
>>> information could I provide to solicit some direction for overcoming
>>> these latest string of mpi errors?
>>>> Thanks,
>>>> Dave
>>>> David F (AREVA NP INC)
>>>> Sent: Friday, July 23, 2010 4:29 PM
>>>> Subject: [mpich-discuss] cryptic (to me) error
>>>> With my firewall issues firmly behind me, I have a new problem for
>>>> the
>>> collective wisdom. I am attempting to run a program to which the
>>> response is as follows:
>>>> [mcnp5_1-4 at athos ~]$ mpiexec -f nodes -n 12 mcnp5.mpi i=TN04
>>>> o=TN04.o
>>>> Fatal error in MPI_Comm_dup: Other MPI error, error stack:
>>>> MPI_Comm_dup(168).................: MPI_Comm_dup(MPI_COMM_WORLD,
>>>> new_comm=0x7fff58edb450) failed
>>>> MPIR_Comm_copy(923)...............:
>>>> MPIR_Get_contextid(639)...........:
>>>> MPI_Allreduce(773)................:
MPI_Allreduce(sbuf=MPI_IN_PLACE,
>>> rbuf=0x7fff
>>> 58edb1a0, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>> MPIR_Allreduce(228)...............:
>>>> MPIC_Send(41).....................:
>>>> MPIC_Wait(513)....................:
>>>> MPIDI_CH3I_Progress(150)..........:
>>>> MPID_nem_mpich2_blocking_recv(933):
>>>> MPID_nem_tcp_connpoll(1709).......: Communication error Fatal error
>>>> in
>>> new_comm=0x7fff
>>> 97dca620) failed
>>> rbuf=0x7fff
>>> 97dca370, count=64, MPI_INT, MPI_BAND, MPI_COMM_WORLD) failed
>>>> MPIR_Allreduce(289)...............:
>>>> MPIC_Sendrecv(161)................:
>>>> MPID_nem_mpich2_blocking_recv(948):
>>>> MPID_nem_tcp_connpoll(1709).......: Communication error Killed by
>>>> signal 2.
>>>> Ctrl-C caught... cleaning up processes [mpiexec at athos]
>>>> HYDT_dmx_deregister_fd (./tools/demux/demux.c:142): could not find
>>>> fd
>>>> to deregister: -2 [mpiexec at athos] HYD_pmcd_pmiserv_cleanup
>>>> (./pm/pmiserv/pmiserv_cb.c:401): error deregistering fd [press
>>>> Ctrl-C
>>>> again to force abort] APPLICATION TERMINATED WITH THE EXIT STRING:
>>>> Killed (signal 9) [mcnp5_1-4 at athos ~]$ Any ideas?
>>>> Thanks in advance,
>>>> David Sullivan
>>>> AREVA NP INC
>>>> 400 Donald Lynch Boulevard
>>>> Marlborough, MA, 01752
>>>> Phone: (508) 573-6721
>>>> Fax: (434) 382-5597
>>>> David.Sullivan at AREVA.com
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Type: text/xml
Desc: summary.xml
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100902/02fbe667/attachment-0001.bin>
