[mpich-discuss] mpich2 1.3.1 compilation error
Darius Buntinas buntinas at mcs.anl.gov
Tue Nov 30 15:34:47 CST 2010
Hi Grant,
What parameters did you use for configure?
What kind of machine are you using (what does "uname -a" say)?
Also, please send us the file: src/openpa/config.log
-d
On Nov 30, 2010, at 2:27 PM, Grant Tang wrote:
> Hi,
> I am trying to compile mpich2 1.3.1 on the head node of my cluster but
> fail. The OS is CentOS5 with kernel 2.6.11.11. g++ version is 3.4.3. I
> configure the the default configuration option. It reports error when
> make as foloowing:
> gtang at sp:~/tmp/mpich2-1.3.1 ssh$ make
> Beginning make
> Using variables CC='gcc' CFLAGS='   -O2' LDFLAGS=' ' F77='gfortran'
> FFLAGS='  -O2' FC='gfortran' FCFLAGS='  -O2' CXX='c++' CXXFLAGS='
> -O2' AR='ar' CPP='gcc -E' CPPFLAGS='
> -I/home/gtang/tmp/mpich2-1.3.1/src/mpl/include
> -I/home/gtang/tmp/mpich2-1.3.1/src/openpa/src
> -I/home/gtang/tmp/mpich2-1.3.1/src/mpid/ch3/include
> -I/home/gtang/tmp/mpich2-1.3.1/src/mpid/common/datatype
> -I/home/gtang/tmp/mpich2-1.3.1/src/mpid/common/locks
> -I/home/gtang/tmp/mpich2-1.3.1/src/mpid/ch3/channels/nemesis/include
> -I/home/gtang/tmp/mpich2-1.3.1/src/mpid/ch3/channels/nemesis/nemesis/include
> -I/home/gtang/tmp/mpich2-1.3.1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor
> -I/home/gtang/tmp/mpich2-1.3.1/src/util/wrappers
> -I/home/gtang/tmp/mpich2-1.3.1/src/util/wrappers'
> make all-local
> make[1]: Entering directory `/home/gtang/tmp/mpich2-1.3.1'
> make[1]: Leaving directory `/home/gtang/tmp/mpich2-1.3.1'
> make[1]: Entering directory `/home/gtang/tmp/mpich2-1.3.1/src/mpl'
>  CC     mpltrmem.lo
> src/mpltrmem.c: In function `MPL_trmalloc':
> src/mpltrmem.c:228: warning: cast from pointer to integer of different size
> src/mpltrmem.c:230: warning: cast from pointer to integer of different size
> src/mpltrmem.c:264: warning: cast from pointer to integer of different size
> src/mpltrmem.c:265: warning: cast from pointer to integer of different size
> src/mpltrmem.c:266: warning: cast from pointer to integer of different size
> src/mpltrmem.c: In function `MPL_trfree':
> src/mpltrmem.c:306: warning: cast from pointer to integer of different size
> src/mpltrmem.c:327: warning: cast from pointer to integer of different size
> src/mpltrmem.c:376: warning: cast from pointer to integer of different size
> src/mpltrmem.c:378: warning: cast from pointer to integer of different size
> src/mpltrmem.c:385: warning: cast from pointer to integer of different size
> src/mpltrmem.c:387: warning: cast from pointer to integer of different size
> src/mpltrmem.c:407: warning: cast from pointer to integer of different size
> src/mpltrmem.c: In function `MPL_trvalid':
> src/mpltrmem.c:451: warning: cast from pointer to integer of different size
> src/mpltrmem.c:460: warning: cast from pointer to integer of different size
> src/mpltrmem.c:470: warning: cast from pointer to integer of different size
> src/mpltrmem.c:493: warning: cast from pointer to integer of different size
> src/mpltrmem.c:494: warning: cast from pointer to integer of different size
> src/mpltrmem.c: In function `MPL_trdump':
> src/mpltrmem.c:535: warning: cast from pointer to integer of different size
> src/mpltrmem.c:551: warning: cast from pointer to integer of different size
> src/mpltrmem.c: In function `MPL_trrealloc':
> src/mpltrmem.c:736: warning: cast from pointer to integer of different size
> src/mpltrmem.c:762: warning: cast from pointer to integer of different size
> /tmp/cc0vwOnf.s: Assembler messages:
> /tmp/cc0vwOnf.s:53: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:117: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:379: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:401: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:500: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:518: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:536: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:627: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:682: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:833: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:858: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:888: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:913: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:962: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:1018: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:1059: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:1086: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:1157: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:1175: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:1253: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:1321: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:1486: Error: suffix or operands invalid for `mov'
> /tmp/cc0vwOnf.s:1536: Error: suffix or operands invalid for `mov'
> make[1]: *** [mpltrmem.lo] Error 1
> make[1]: Leaving directory `/home/gtang/tmp/mpich2-1.3.1/src/mpl'
> make: *** [all-redirect] Error 1
> I don't now wha's wrong. Can anybody help me?
> Thanks,
> Grant Tang
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
