[mpich-discuss] Parallel jobs
Talla
jtalla at gmail.com
Mon Nov 29 10:55:54 CST 2010
Hello Gus,
Thank you for pointing me to this error, but I am new to Linux world so I am
wondering if you have a ready script or commands to add stdin flags to
mpirun?
Thanks
On Mon, Nov 29, 2010 at 7:34 PM, Gus Correa <gus at ldeo.columbia.edu> wrote:
> Hi Talla
> It sounds like all processes are trying to read from stdin, right?
> Stdin/stdout are not guaranteed to be available to all processes.
> Have you tried to add these flags in your mpiexec/mpirun
> command line: "-s all" ?
> Check the meaning with "man mpiexec".
> My two cents,
> Gus Correa
> Talla wrote:
>> Hello,
>> this issue is consuming all my time with no luck. I can submit any job
>> without any error message *BUT ONLY* when I am using *one* CPU, when I am
>> using more than one CPU, I got the error message : " *forrtl: severe (24):
>> end-of-file during read, unit 5, file stdin* ". I got this error line
>> repeated as many as the number of CPU's I am using.
>> Which mean that the other nodes are not doing any job here. So if you can
>> help me to link the other nodes so I can take advantage of all the nodes.
>> I have 8 PC and each one has 2 CPU (in total I have 16 CPU).
>> I tested the cluster using the following command: /opt/openmpi/bin/mpirun
>> -nolocal np 16 -machinefile machines /opt/mpi-test/bin/mpi-ring
>> and all the nodes can send and receive data like a charm.
>> Just to mention that I have Rocks Clustering software with open centOS.
>> The code I am using is called ABINIT and it is impeded as a plugin in a
>> visual software called MAPS.
>> Your help is really appreciated.
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101129/b8e758d6/attachment-0001.htm>
